MX1 + FP Red
Old Nov 16, 2009 | 03:25 PM
DG Motors's Avatar
MX1 + FP Red
Originally Posted by t12ung
Yeah I might out cams next but I can't decide between the Cosworth MX1 or the Kelford 214B. I think I'm going to research it a little bit more and make a decision early next year.
Beautiful power. Brian knows his stuff! Always enjoy studying his graphs...
Here is an mx1 power band with a red @ 26.5psi/93 Octane
FP Red @ 26.5psi/93 Octane
Here is a kelford 214b on the stock turbo @ 32psi/93 Octane
Stock Turbo @ 32psi/93 Octane
Here is our evo x blouch 2.0/mx1 cams/25psi:
Here is another clients car HTA3586/Kelford 214b/25psi/93Octane:
Just throwing out some data. I personally feel the 214b are the way to go. At the time we chose the mx1 for our personal car since nothing else was available. We will be switching out for the 214b's or hopefully a more aggressive kelford grind when available.
Again, sweet looking curve and power on GST's dyno. That car must feel insane!
Old Nov 16, 2009 | 08:20 PM
Clipse3GT's Avatar
You are saying the Kelfords B's are the way to go on a larger turbo and the MX1 are for a stock sized turbo?
Old Nov 17, 2009 | 06:01 AM
DG Motors's Avatar
From what I have gathered, big boost on a the stocker will broaden out the mid-range big time. I feel the 214b's are the way to go right now over any cam selection on the evo x for any size turbo. Time will tell when more selections are available and put through real testing.
Old Nov 17, 2009 | 07:42 AM
t12ung's Avatar
Thanks for the data DG Motors I don't have any local guys with cams so your info is great. I was more leaning on the Kelford 214B's also because of the springs and stuff but I'm just worried the install will be lots of money.
Old Nov 17, 2009 | 08:38 AM
murlo26's Avatar
Well I will let you know the cosworth results on a port FP red on E85 here soon, the Red is here, intercooler on the way. Need to order fuel upgrades and clutch still and a few other pieces, so it might be a little while but i will get it done
Old Nov 17, 2009 | 11:28 AM
DG Motors's Avatar
Depends where you go but yes cams+valve springs are a costly install. I always advise to install springs/retainers on any cam install so you can save some cash down the road. Good luck with your decision.
Old Nov 17, 2009 | 12:12 PM
murlo26's Avatar
Very good point here, I kind of regret not just throwing in some springs/retainers with mine.
I am keeping the factory rev limit for now. But when i decide to up it, i will pull the head and build it fully, springs/retainers and valve job of some sort with new valves to make it worth while to pull it off.
If you don't plan on going too big on the turbo the MX1's will probably work great and you don't have to do springs/retainers. Try and keep your end goals in mind. I know most our goals change when we get bored though so its hard
Old Nov 17, 2009 | 12:26 PM
DG Motors's Avatar
Yes, as the MX1's will "probably" work great we are talking about rpm if you are going to be taking your car to the drag strip. Remember 116-118mph will have you banging off an 8,000rpm rev limit in 4th gear. Springs and Retainers now will allow you to break into the 120+mph with out having the need to throw 5th gear, change your tires, and or gear ratio....It won't only save you cash, but a big deal of aggravation at the track if you don't live around the corner from one. For us New Yorker's It's a minimum of 4-6 hours there and back....
Just had this happen to a good customer of ours in PA. Blouch 2.0 (390whp) 11.79 @ 117.5 banging off an 8,000rpm rev-limit. Stock cams. We will be upgrading the cams and valve springs shortly...
Old Nov 17, 2009 | 01:49 PM
Noize's Avatar
EvoM Administrator
Please start your own thread in the future instead of piggybacking off another vendor's thread. Thanks.
Old Nov 17, 2009 | 02:51 PM
DG Motors's Avatar
I wasn't piggybacking and never intended to Hi-jack the thread. I was just giving out some data to the customer who was asking about a certain camshaft selection. Thank You for making my own thread though
Old Nov 17, 2009 | 03:46 PM
Clark_Kent's Avatar
Good information Pete. I may need to see you again to get those camshafts, springs/retainers installed.
Old Nov 17, 2009 | 05:14 PM
EVOOOOO's Avatar
How do the Kelford 272's stack up against the 214b?
Old Nov 17, 2009 | 07:10 PM
DG Motors's Avatar
Sounds Good, I will take care of you!
Can you please be more specific? Do you mean the Kelford 272 for 8/9 against the Kelford 214b for evo X?
Old Nov 18, 2009 | 06:39 AM
XEVOX08's Avatar
Well lets see how my car reacts with the 272 brian crower cams I bet the car is gonna perform well....DG motors will do the install and tune and I will right a review when I am done. Pete I just like to be different sorry hahah
Old Nov 18, 2009 | 07:03 AM
EVOOOOO's Avatar
Sorry thought it was understood we were talking about the ten cause we are under the X area my appologies.....And no I mean the Kelford Stage 2 272's Vs the 214B's for the Evo X. Im hoping they stack up well b/c im hearing good things from the 214b's. I do plan to go to a larger turbo app which is why i did the stage 2's but was this the wrong cam to select?
