HB Speed Tuned FP Red on E85 FlexFuel
Old Feb 17, 2010 | 07:44 AM
ArchieBabes's Avatar
474WHP 384WTQ
Next step is to upgrade the WGA and shoot for higher boost levels and hit 500whp on E85
This is only on 30 PSI of boost.
When we upgrade the WGA we wil shoot for higher boost levels and make 500WHP
1. FP RED
2. Cossworth MX1 Cams
3. Nisei Upper and Lower IC Pipes
4. Nisei Intake Kit For Stock Airbox
5. AMS Widemouth 02/ Downpipe Combo
6. UR Test Pipe
7. 5 Zigen Dual Catback Exhaust
8. ACT Heavy Duty Clutch Upgrade
9. TTP 2400cc High Impedance Injectors
10. Blaqops Double Pump Setup with MAF Controller
11. AGP Intercooler
12. ACT Flywheel
13. 3 Port BCS
14. AEM Intake
91 Pump Gas E85 comparison.
Old Feb 17, 2010 | 08:16 AM
mlomker's Avatar
Do you miss the torque from the stock turbo on E85 (guessing from your sig)?
Old Feb 17, 2010 | 08:28 AM
TTP Engineering's Avatar
Torque curve really does not make much sense.
Old Feb 17, 2010 | 08:32 AM
redbyme's Avatar
I wish I had e85 close to me....
Old Feb 17, 2010 | 08:33 AM
I don't miss it at all.
Old Feb 17, 2010 | 11:53 AM
HB Speed's Avatar
nor does the fact that these injectors wont idle for ****
even though you tell customers they are fine
Old Feb 17, 2010 | 01:25 PM
The customer stated he would be using openecu to tune the vehicle not an accessport. We do not sell AP's for this reason.
We are not surprised that you cannot get the injectors scaled correctly using Cobb AP which is why when he stated he was using OpenEcu Ecuflash to tune the car to run on E85 we stated that they would work fine.
These injectors support 500-1200hp applications when used in a 4cyl, 2.0L application.
We are currently using them on a number of Evo X's and they work perfect for us as well as every other tuning facility we have sold them to.
Old Feb 17, 2010 | 02:06 PM
HB Speed's Avatar
Thats funny because MY version of AP software has every table i have in OS ( and i can pretty much guarantee i have more useable tables than you do )
tell me why AP cant tune it again?
The inj scaler is the same in AP as it is in OS.
Please Mr TTP enlighten me
Old Feb 17, 2010 | 02:22 PM
supergengo's Avatar
Sweet power Archie!
HB,
Any chance I could replicate this curve using meth/h2o injection instead of E85?
Old Feb 17, 2010 | 02:26 PM
HB Speed's Avatar
Originally Posted by supergengo
Sweet power Archie!
HB,
i can get close !
with an HFS-6 and alot of meth
Old Feb 17, 2010 | 02:37 PM
supergengo's Avatar
HFS-3 kit will have to do... got one on the group buy!
Can you PM a recommendation on injectors? I don't expect to run E85 so i'm guessing 1000cc should be okay.
Old Feb 17, 2010 | 02:49 PM
1slowassevo's Avatar
I agree and the tq is low for that boost level on e 85 and with those mods...
Old Feb 17, 2010 | 04:30 PM
lowkey's Avatar
Registered User
Actually that torque curve does not look much diffrent from this one:
https://www.evolutionm.net/forums/ev...ets-kit-4.html
Old Feb 17, 2010 | 05:23 PM
It looks nothing like an externally twin gated, twinscroll T3 turbokit capable of 700whp.
Its an FPRed which should peak tq low rpm and taper down not the opposite. You are not supposed to have higher torque later in the RPM range unless there is boost creep.
Old Feb 17, 2010 | 08:02 PM
Clark_Kent's Avatar
Dyno Results fellas...nothing more. If you have a problem hash it out via PM. This is not an open forum to lambaste each other.
