E85 375hp/400tq
Old Apr 16, 2010 | 07:24 AM
goofygrin's Avatar
E85 375hp/400tq
"Stage 2" custom tune @ Cobb in Plano
Honestly it doesn't feel much faster than my last tune (only hardware change was a surge tank). I picked up 8hp/30tq from that tune (different dynos, but both the same type).
We did two tunes, one was an all out and the other was a NASA tune so that I could fit in the power to weight ratio I needed in order to run non-dot-r slicks.
power mods:
AEM intake
T1R IC pipes & turbo outlet
ETC 4" FMIC
AMS o2 housing
AMS test pipe
UR catback
EvolutionDynamic "mac valve" 3 Port
DW 1000 cc injectors
MDR surge tank kit
Attached Thumbnails E85 375hp/400tq-dyno4.15.2010.jpg
Old Apr 16, 2010 | 12:12 PM
goofygrin's Avatar
Youtube video: http://www.youtube.com/watch?v=pYaAd8tCC40
The "opensource" map that they are listing there is a buggy map I built, not the one the other tuner built, so it's a skewed a bit.
Old Apr 16, 2010 | 05:52 PM
lowkey's Avatar
Registered User
Back in the AP fold? Looks like your car has about 12 hp and 28 ft/lb on mine. Is it the 3 port, bigger injectors, test pipe or intake or all combined? Here's a comparison graph...
Attached Thumbnails E85 375hp/400tq-untitled.jpg
Old Apr 17, 2010 | 01:14 PM
kmart888's Avatar
Nice Power! Is the MDR surge tank aluminum? Any compatability problems with E85?
Old Apr 17, 2010 | 02:10 PM
Psiaddiction's Avatar
congrats thats a nice curve
Old Apr 20, 2010 | 08:30 AM
SilverEvoX's Avatar
not bad man
Old Apr 20, 2010 | 10:35 AM
Ruff Ryda's Avatar
F'ing dope! I would love to have your setup.
Old Apr 20, 2010 | 11:06 AM
MR. Tim's Avatar
Nice numbers
Old Apr 20, 2010 | 12:57 PM
mlomker's Avatar
If you are running a cat then that's undoubtedly the difference.
Old May 5, 2010 | 11:59 AM
krisiun's Avatar
It also looks like he is running about a lb more of boost if I am reading it correctly.
Old May 6, 2010 | 03:53 PM
nikkadanny's Avatar
did you do a before and after dyno on cobbs dyno?
Old May 6, 2010 | 04:41 PM
mrfred's Avatar
You're leaving a ton of boost on the table at higher rpms. I hold about 26.5 psi out to 5500 rpm and then taper down to about 22 psi at 7000 rpm. You could easily clear 400 whp if you did the same.
Old May 6, 2010 | 04:46 PM
murlo26's Avatar
With an X turbo you do?
Old May 6, 2010 | 04:54 PM
mrfred's Avatar
Ooops. Forgot I was in the Evo 10 dyno thread. Forget my comment above.
Old May 6, 2010 | 05:03 PM
murlo26's Avatar
Lol, was about to raise the BS flag
r34p3rex
Apr 12, 2015 02:49 PM
krisiun
North Texas Evo Club (NTEC)
28
Dec 11, 2010 08:53 PM
Chris@AMS
Evo X Dyno Results
65
Aug 6, 2009 12:58 PM
X EVO X
Evo X Dyno Results
10
Jun 22, 2009 08:50 PM
Chris@AMS
Automotosports - Illinois
Nov 19, 2008 09:19 AM
