E85 BBX, 100% Stock Exhaust
Old May 17, 2010 | 03:08 PM
unowned's Avatar
As most of the old school people know I already have a track only Evo so I don't need to have the absolute most potential from my 2008 daily driven Evo with 28k miles. I chose not to have a wideband installed with my E85 upgrade to keep things stealth looking which Bryan also said he would give me his ultra conservative tune. Boost peak is 27 psi falling to 24.5 PSI at 7700 Rpms (car would get grumpy with higher redline boost because of the stock exhaust). AFRs are 11.8.
The car absolutely screams in the high end and it's not much louder than stock. From the outside and even under the hood you would not be able to tell it was a 450-500 crank HP Evo in disguise (subjectively calculated). Overall I'm super happy with how everything turned out power wise with the car and being as factory as it is.
Thanks to GST and SE without you guys this would never be possible.
I will someday take it to the Drag Strip for Trap Speeds only. It will never be launched. Edit: Traps posted!
Edit 2/5/2013: Might as well post an update. I warrantied the DW1500 injectors with DW1300 injectors and finally replaced them with FIC1100s and a retune @ FFTEC about 5 months ago which actually gave me a power bump of 300WTQ and 385WHP. No more grumpy misfires and crap idle! Still running stock clutch @ 51k miles (25k miles running this setup so far). Fixed broken picture links in first post.
Current Mods:
Nisei UICP
Nisei LICP
GST boost pill
BBX Full Turbo
FIC 1100 injectors
BlaqOps Single pump kit
Sean @ FFTEC tune (E85 only)
No Wideband
No Map switching
Stock downpipe
Stock Cat
Stock catback
Stock Cams
Stock FMIC
Stock Clutch
Old Bryan@GST before injector replacement E85 Touch Up Tune results: 370 WHP / 285 WTQ
Previous Stock Turbo 91 Tune Dyno: 295WHP/ 309 WTQ - Bryan@GST
Factory Stock Dyno: (yes 9.X AFRs) - Bryan@GST
Factory looking engine bay:
best trap with no launch 117.463 Trap. my 60' was a nice and slow 2.925
Old May 17, 2010 | 03:31 PM
Frankiago's Avatar
Cool, put the plastic engine cover back on
How does the lack of torque feel? Do you like that extremely gradual power? Are you willing to do a resonated test pipe and a stock-looking dual exit exhaust?
Old May 17, 2010 | 03:37 PM
unowned's Avatar
Haha I hate the look of the plastic in the engine bay so I'll never put that thing back on. i love engines in their raw looking form like my 4g63 race Evo.
I can barely tell I have less peak torque than with the stock turbo because once i'm at 4.5k rpms the car just keeps pulling harder and harder instead of dying off because of the maxed out stock turbo. It definitely suits the type of power I wanted (high end quickness). Like i mentioned earlier I already have a seriously loud and completely gutted track Evo (used to drive on street before i picked up the X), so it's a nice change to have a very fast non attention grabbing Evo when I decide to get on it or go on long distance drives.
Old May 17, 2010 | 04:29 PM
Evo a Mula's Avatar
nice tune and great power for such small mods i like it.......launch it once pleaseeeeeeeeeeeeeeeee!!!!!!!!!!!!!!!!!!!!!!!!!!!! !
Old May 17, 2010 | 05:46 PM
murlo26's Avatar
Nice numbers for what you have, but god I bet that motor wishes you would free up that exhaust stream
Old May 17, 2010 | 06:26 PM
Clark_Kent's Avatar
Great power given the mods. Thanks for posting up. Stealth mode!
Old May 17, 2010 | 09:02 PM
Moostafa29's Avatar
Perfect sleeper! I'm sure it must be a blast!
Old May 17, 2010 | 09:17 PM
unowned's Avatar
i think i saw you pull into the 76 on Mowry, Saturday around noon, i was heading to the BevMo to bring Bryan some of his fav ale.
Old May 18, 2010 | 12:23 AM
unowned's Avatar
keeps the torque low, which keeps my clutch and rods happy
Old May 18, 2010 | 05:44 AM
Moostafa29's Avatar
Wasn't me, but there is another WW X I've seen in the area quite a few times. Its a MR. Unfortunately I'm always in my other car when I see them though.
Old May 18, 2010 | 07:06 AM
murlo26's Avatar
I hear that.
Old May 18, 2010 | 08:42 AM
omni-star's Avatar
Very nice results!
Old May 21, 2010 | 07:48 AM
unowned's Avatar
heading to Sacramento Raceway on the 26th before 5 pm and leaving around 6:30pm with my X. I plan on going for trap speed with no launch. I'm excited to get some benchmarks on the car to put up against the dyno numbers.
Old May 21, 2010 | 11:33 AM
kwlevo's Avatar
u need to replace that exhaust. it's so sad to see a beast with a muzzle on.
Old May 21, 2010 | 02:32 PM
unowned's Avatar
