Dyno testing: PPI & Mil.Spec ported parts!
Old Aug 18, 2011 | 06:29 AM
Kracka's Avatar
First of all I want to thank Wayne at PPI and Aby at Mil.Spec for the port work, Rmondoh for lending a hand with the installs, and also the guys at Cobb Tuning - Plano for working with me on these back-to-back comparisons and the consistently great tunes. I think it really says something when whether it be 20F or 110F the car runs just awesome!
2010 Evo X GSR SSS: stock turbo/93 octane pump gas
before
AFE Stage 2 DryflowS intake
Perrin turbo inlet pipe
Nisei UICP
MAP FMIC
MAP o2 elim downpipe
ETS testpipe
Cobb catback
Grimspeed 3-port BCS
Cobb Accessport (protuned by Calvin @ Cobb - Plano)
after
+Mil.Spec ported intake manifold
+Mil.Spec 64mm ported throttle body
+MAP phenolic heat barrier intake manifold gasket
+PPI extreme ported/silver coated exhaust manifold
+retune (same AFR, slightly less boost)
I am thrilled with the results! The car definitely pulls harder will the new mods and torque hits hard. It feels great on the streets, I definitely recommend these parts; solid gains on my stock turbo/pump gas car, they'll only get better with bigger turbos.
Old Aug 18, 2011 | 07:23 AM
rmondoh's Avatar
I also did the same to my car with the help of Kracka on the installs.
2008 Evo X GSR SSS: stock turbo/93 octane pump gas
before
AMS intake (w/AMSoil Filter)
AMS UICP
AMS LICP
AMS FMIC
Cobb downpipe
Megan testpipe
Specialty-X catback
after
+retune
Results
Old Aug 18, 2011 | 08:00 AM
Kracka's Avatar
Nice, thanks for posting your results too Mondo! I think right now what's holding you back from my torque numbers is your stock o2 housing...but since Murlo is now selling his AMS widemouth...
It's amazing how similar our curves are though, I think both of our stock turbos are beyond maxed:
Old Aug 18, 2011 | 08:10 AM
SilverEvoX's Avatar
Really nice numbers for pump gas!
Old Aug 18, 2011 | 09:02 AM
scheides's Avatar
EvoM Moderator
Ported IM/TB are definitely on my wishlist...it's hard to imagine needing more power but with gains like this on the stock turbo/pump gas, I cannot wait to see what it does on my BBX/E85 setup!
Old Aug 18, 2011 | 09:04 AM
rmondoh's Avatar
Not a problem dude. Always glad to help provide some data! It just further shows that the gains were not a fluke. We have different setups on our cars and really the only difference between our cars is that I still have the stock o2 housing and you don't. Speaking of which, Murlo's AMS o2/dp might be a nice addition to my build to get back on par with your numbers.
Old Aug 18, 2011 | 09:21 AM
justin81's Avatar
How much for everything?
Old Aug 18, 2011 | 09:25 AM
Kracka's Avatar
I believe regular prices for the porting are $150 from PPI (EM) then $375 from Mil.Spec (IM & TB). We had our exhaust manifolds coated locally by SPC in Arlington. Then the MAP phenolic gasket is $40 I believe.
Old Aug 18, 2011 | 09:28 AM
justin81's Avatar
Not bad. Graphs look great!!
Old Aug 18, 2011 | 09:32 AM
Kracka's Avatar
I can also add that even with the larger throttle body the drivability of my car remains unchanged. The car still does great sitting in traffic, hot days, A/C on, whatever! Getting on/off the throttle is still very smooth, no weird bucking or anything. Even before tuning it was surprising how well the X ECU was able to compensate for the larger throttle body, something my IX's ECU could never do.
Old Aug 18, 2011 | 10:30 AM
Aby@MIL.SPEC's Avatar
Awesome results guys
Thanks for posting them as well
The ported TB & Int Mani are $375- w/exchange
I currently have 2 BRAND SPANKEN New tb's available. Meaning, you'll receive a new 64mm tb for your used tb That is till the new units are gone
Old Aug 18, 2011 | 12:33 PM
RazorLab's Avatar
Can you guys also post your before/after boost curves overlayed on each other?
Old Aug 18, 2011 | 12:37 PM
rmondoh's Avatar
Old Aug 18, 2011 | 12:38 PM
Kracka's Avatar
Boost is already in the charts but is kind of hard to see (thin dotted line). Just for you though, I'll make the boost a thick easy to read line
Here's mine:
Old Aug 18, 2011 | 12:44 PM
tonyboy's Avatar
hey rmondoh,
is that cobb dp just an add on dp not with an o2 housing right? great results btw guys!
