FP GREEN/MX1/ tuned by Clipse
I don't care if he was running over penguins in the process, colder temps don't add ~70whp. I've dyno'd everywhere from in the teens to the 120's F (dyno room temp, not outdoor temp) and numbers don't vary that much. Like I said, this car needs to get on a real dyno with charts for proof then we'll talk.
And ya one day I'll do "REAL" dyno runs but till then u have to deal with VD #s
Btw here is VD vs. mustang Dyno of one Evo m member.
Found that pretty interesting actually
https://www.evolutionm.net/forums/ev...al-dyno-s.html
E tune. My power band progressed each time I got new map. So I dunno car feels fast, way faster then my other tunes so it's gotta be making more power then previous tunes.
Anybody that actually understands Mivec knows that it's not a HP adder, it's a spool and torque adder. Up top it is not a miracle power adder at all, unless your mivec map was horrible to begin with and then tuned properly, getting your power back.
I will also agree on Kracka's comment, 70whp from a colder day? Again, *ANY* true dyno operator that has been operating a dyno for more then a year knows that is hogwash.
These VD threads are getting seriously out of hand.
Just doing the math on 800cc injectors and horsepower capability will show you this is not possible.
The only way you gained 40 hp when the temp dropped is if it was tuned warm or even hot at around 26 psi and your now running 31 psi. It's not the cold it's the higher boost.
I tend not to pay attention to the numbers on VD's so much as the shape of the tq/hp. VD is VERY touchy, on the same road running one direction vs another makes 30whp change (back to back) due to a slight grade (maybe 1*). So for tuning comparisons I have to use every other run.
To sum it up, cold weather gives insane amount of power increase.
^ I would say that cold weather defintely does make the car run a little faster, but in no way even close to 70whp.
Tops probably 10-15hp. From an 85 degree day to a 35 degree day. 70whp is just ridiculous, why would anyone mod? Why not just wait for it to get cold
Agree ^^^^
And holly **** lots of haters here lately on Evo m
Just posted whatever VD Showed. Figured I'd share but i guess it was a mistake.
Its all good man. Some just might be skeptical of the high power #'s, but as long as the car runs good and your happy, thats all that matters.
