FP GREEN/MX1/ tuned by Clipse
Old Feb 23, 2012 | 08:33 PM
  #31
evox_4x4's Avatar
exactly...go strap it to sunnys dyno dynamics and prove all the haters.
Originally Posted by HAHAV8
Its all good man. Some just might be skeptical of the high power #'s, but as long as the car runs good and your happy, thats all that matters.
Old Feb 23, 2012 | 08:38 PM
  #32
olo's Avatar
olo
Im thinking about it.
Old Feb 23, 2012 | 08:45 PM
  #33
guswaym's Avatar
we loaded the datalog from my final dyno run into virtual dyno and it was almost exact
Old Feb 23, 2012 | 08:55 PM
  #34
sstevojr's Avatar
Oh course it was, the data from your dyno run was in a controlled environment. That's the key difference, VD has to assume ideal circumstances. A strong tail wind will give you 15whp extra.
This is no way saying the OP doesn't have a beast on his hands (wanna trade!), just to take the numbers with a grain a sand.
Old Feb 23, 2012 | 08:59 PM
  #35
kpr's Avatar
kpr
Well my last Dyno on a dynojet was data logged , dropped into VD and was within 10whp on 3 pulls.
Old Feb 23, 2012 | 09:03 PM
  #36
sstevojr's Avatar
Does no one read:
OF COURSE IT WAS, IT WAS A CONTROLLED ENVIRONMENT!!!
What is so difficult to understand about this?
If VD couldn't return the same results as the log from a dyno, it would be a complete failure.
Old Feb 23, 2012 | 11:15 PM
  #37
tscompusa's Avatar
almost every other graph i see on here has this same dangerous mistake.. look at the boost curve, then look at his AFR at full boost.. 13 AFR? you think 13 AFR is safe to run at full boost? you need to start richening the car much sooner, you cant tune for spool until the last minute or you're gonna run lean at peak boost like your graph is showing.
Old Feb 24, 2012 | 05:15 AM
  #38
Supraboy1's Avatar
Originally Posted by olo
Agree ^^^^
And holly **** lots of haters here lately on Evo m
Just posted whatever VD Showed. Figured I'd share but i guess it was a mistake.
There are literally hundreds of Dynos all over Canada. Its not you specifically. Its just too easy to go and use a DYNO for real and not a made up one. They are NOT accurate. I used a real dyno on my car which made 414 HP on pump gas and on VD made 630. With all the correct info there..
Old Feb 24, 2012 | 06:34 AM
  #39
olo's Avatar
olo
Will do that thx , finally some good contribution to this thread, that's what I was looking for not just full on hate VD #.
Old Feb 24, 2012 | 07:14 AM
  #40
jyamona's Avatar
I agree with this.
Old Feb 24, 2012 | 12:51 PM
  #41
EvoX-11's Avatar
Agree ^^^^
Hater? I could give a rats *** about ur numbers. I was trying to explain other people why ur numbers are higher than usual.
Old Feb 24, 2012 | 08:17 PM
  #42
SilverJesterGSX's Avatar
I wonder how hard it would be to add elevation changes to VD's calculations. Like if you could log elevation changes with a phone's gps sensor and add that to the log.
Do eeeeet! I love the idea of VD, but I would really like to see more people do both VD and then a real dyno.
Old Feb 28, 2012 | 05:39 AM
  #43
Hiboost's Avatar
478 whp on an a typical Dynojet would be low 11's @ 125 mph which would also put you at about 95% injector duty cycle on the 800cc injectors. It's not totally impossible but I can understand some doubting it. Of course going to the drag strip would still be hard to back that up since anytime you shoot past 118 mph or so with a 5 speed you are forced to reach for 5th gear messing up the run.
In the end if you can get consistant results with the road tuning and virtual dyno, that's all that matters and you can still use it as a tool for before and after results. I'm assuming the original run was much lower than your final numbers so you definitely had gains from the tuning.
EndlessRed
Evo X Dyno Results
10
Feb 4, 2013 04:58 PM
305EVOx
27
Jan 8, 2013 07:55 AM
jackal5555
Evo X Dyno Results
12
Dec 21, 2012 10:14 PM
wrx2evoIX
57
Nov 22, 2011 07:47 AM
tjac357
Evo X Dyno Results
36
Apr 21, 2011 10:02 AM
