2010 Evo X GSR Bolt-Ons 360/340
Old May 15, 2012 | 05:50 PM
toodrunk2see's Avatar
After a couple of months I finally got my car pro tuned and it made me realized I really needed a new wastegate. Car was hitting 27 psi but would taper to 19 psi.
Mods
Cobb AP
AMS Widemouth DP
AMS Test Pipe
AMS Cat-back single exit
AMS Intercooler with pipes
AMS CAI
HOA EBCS
Crushed stock bov
Torque Short Shifter
AMS Base/Underhood/5 speed gate selector
AEM water/meth kit (not installed yet)
Tial QR bov (in the mail)
I am new to the forums and can't figure out how to show the pic of the dyno so I attached it. I think a new wastegate will fix a lot of the boost tapering so that's the next thing I am getting. Probably the FP wastegate with 18psi spring since I want to do FP red at some point and time.
Attached Thumbnails 2010 Evo X GSR Bolt-Ons 360/340-2012-05-15-20.19.59.jpg
Old May 15, 2012 | 06:37 PM
ugakirk's Avatar
Stock fuel pump? I'm getting tuned in a week or two and the tuner is trying to tell my the X's need a fp, which I dont believe. The stock one seems to work well until you upgrade the turbo.
Nice numbers.. And a wastegate might help a little, but the problem is the turbo.. The stock turbo on the X is pretty small and can't keep up with the air flow at higher rpms.
Old May 15, 2012 | 06:46 PM
Yup stock pump. Your right the stock turbo doesn't hold boost at the top end very well but I still don't think I should be tapering that bad. If I can get it to hold 22-24 psi I would be happy.
Old May 16, 2012 | 10:12 AM
AWDTerror's Avatar
The problem isn't with the pump, it's the injectors. @260ish load level injector duty cycle is around 95% on 93oct.
I wouldn't do a wastegate unless you do injectors, the turbo flows enough to ventilate your block, and you're probably already pushing the injectors to the limit.
Old May 16, 2012 | 12:34 PM
Kento240's Avatar
Uhh, I'm pretty sure the stock turbo generally tapers down to around 18-19 psi. I have yet to see anyone taper above 20 psi above 7000 rpms. The stock turbo is just out of steam up top.
Old May 16, 2012 | 12:39 PM
I was running the stage 2 map on the cobb and I never saw it hit over 90% duty cycle but I know they are close to being maxed out now. From about 6800 to redline my AFR did dip blow 11 to 1 because of the boost dropping off so bad. I also know its prefered to not push them pass 88% so I might do the cobb 255 pump kit, 850 injectors and wastegate. Thanks for the inputs because that was something I completely forgot to ask my tuner about.
Old May 17, 2012 | 08:00 AM
dcdk's Avatar
Very good result!!Damn
Old May 17, 2012 | 08:57 AM
Evod350z's Avatar
Thats what i thought...
Old May 17, 2012 | 09:30 AM
I have looked at a lot of the dyno charts on here with stock turbo but I have yet to see anyone run an upgraded wastegate on the stock turbo. Does anyone think that might be why it tapers so bad besides me? I am going to give it a shot. Either way like I said before I plan on running a fp red so if I get the fp wastegate with 18psi and it does help no big deal.
Old May 17, 2012 | 11:45 AM
tdi_hatch's Avatar
nice!!!
Carloverx
Mar 2, 2020 12:21 PM
Silk
Jul 13, 2009 06:08 AM
scottatyamaha
23
Mar 26, 2007 05:36 PM
evo ippo
22
Nov 6, 2006 07:50 PM
nyrican
Aug 7, 2005 04:15 PM
