The official "prosport gauges" thread
Old Jul 6, 2009 | 10:49 PM
  #466
D-Mon3y69's Avatar
how good is the wideband? price for 52mm blue premium peak warning boost, egt, oil pressure, and wideband shipped to 84401? total price and seperate prices please if that's not too much trouble.
Old Jul 7, 2009 | 06:47 AM
  #467
Prosport Gauges's Avatar
The wideband is awesome, it uses the latest Bosch sensor~4.9 with the widest range available. We worked closely with bosch and they are matched perfectly. I'll PM you prices.
Old Aug 1, 2009 | 12:46 AM
  #468
evil03's Avatar
anyone out there that is having a hard time seeing the gauge in the daytime??
i am running a 60mm with peak... white in the day amber in the night... mounted on the A pillar and using sun visor as well...
wiring....
red to the batter with a 1 amp fuse...
black to a grounding point under the dash...
white to a 12v switched lead off the fuse box with a 3 amp fuse as well..
orange to a on off switch to the same switched lead off the fuse box above...
the gauge is getting 12v and switched from white to amber when i turn on the on and off switch
but i can barely see the gauge in the daytime... in both color....
please help me out....
BTW great gauge... but i dont know if i like it much if it gonna never really work during the day lol....
Old Aug 1, 2009 | 11:46 AM
  #469
evil03's Avatar
Bump for INFO
Old Aug 1, 2009 | 12:06 PM
  #470
nikkadanny's Avatar
i have mine on white in the day and amber at night and they been great for me. only thing is that the boost gauge readslike 2psi low
Old Aug 1, 2009 | 05:03 PM
  #471
evil03's Avatar
how is it wired? i mean its hell dark when its in the day light... it gets washed out... i will do a pic 2maros... and show you guys....
Old Aug 3, 2009 | 06:37 AM
  #472
wiring....
You need to take the fuse's off. You do not need these and this may be causeing dim lighting.
Old Aug 3, 2009 | 09:37 AM
  #473
rickay726's Avatar
prosport guages are crap iv gone threw at least 2 of each boost oil press and egt. in the long run there garbage. save your money and get defis.
Old Aug 3, 2009 | 10:02 AM
  #474
Can i have your full name so i can look up your order and see if your even in our return folder??
I like your sig by the way.
Old Aug 4, 2009 | 07:45 PM
  #475
badhabit90's Avatar
Question
having an issue with 52mm oil pressure gauge in my truck. 52mm electronic green/white. says i have pressure 40psi without the engine running. it also doesnt register pressure up above say 45 psi when cold. it normally did this when i first purchased. worked great since i bought it, just some issues perhaps with sender. advice??
Old Aug 4, 2009 | 09:44 PM
  #476
evil03's Avatar
i will try that to see if it fixes the problem... thanks
Old Aug 10, 2009 | 04:01 PM
  #477
evil03's Avatar
nothing its the same... sigh
Old Aug 10, 2009 | 05:31 PM
  #478
2.0Ldoom's Avatar
I love my Prosport Peak/Warning Boost guage it works flawlessly.
Old Aug 11, 2009 | 06:39 AM
  #479
Give us a call for more detailed support. 727-572-9011
Old Aug 11, 2009 | 08:54 AM
  #480
Svendiesel's Avatar
Any info on if the 52mm premium peak/warn Oil temp gauge can be connected to the OEM wiring or does a new line have to be run from the drain plug specifically for the prosport??
