The official "prosport gauges" thread
When the gauge pegs out that indicates an open circuit. Most common open circuits is you lost the ground to the sender (WK) terminal or the green wire going from the gauges to sender has been compromised. Meaning cut, burnt, rubbed through etc..
Thanks,
Too bad my oil press is not working properly if it were I could agree with you on that.
Yea I need to reconnect the grounds. I cur the wires to shorts and they now got pulled out of the connector. This time I'll make them longer and solder the wires to the connector like I should have the first time
PM replied. I am also in the market for 3 gauges if we can get the oil pressure gauge issue resolved.
I need a 52mm, boost gauge, oil press, oil temp. I also need an oil filter sandwhich adapter for an 04 EVO RS if this is where the oil/press/temp sensors would go.
Thanks,
Thanks,
Prosport Gauges: the wire harness in the performance series gauge is literally 2 feet. How do you expect the sender wire to reach all the way to the engine bay when it's like 5 feet away?
Yes the oil filter adaptor plate is all you need for the senders to be installed. It has 4 places for senders if needed..
The quick connect wiring harness is not meant to be used to make it everywhere.. It is a pigtail quick connect harness that each user can simply extend the wires if needed as each vehicle is unique.
Hmm. I disconected the battery to get to something. when I put it back my guages are all messed up. Used be ignition on = white parking lights= amber lights on =amber
now zero power until I flip on the parking lights they are white and lights on are white. WTF all i did was remove the battery and put it back in.
