DVD Hack for the MMCS
Old Nov 11, 2008 | 02:43 PM
  #361
OtakuTTA's Avatar
Originally Posted by ZK
Patch did not work for me. It asked me for to insert the "key" into the slot under the navigation to update. It would not let me continue without the "key".
That would tend to suggest you were using the broken copy that was floating around a while back : the key is only required for navigation updates.
atb.
O.
Old Nov 11, 2008 | 03:15 PM
  #362
KGHtheII's Avatar
OtakuTTA can you post up a version for 30.97?
I'd really appreciate it.
Old Nov 11, 2008 | 03:54 PM
  #363
ZK's Avatar
ZK
atb.
O.
I got the one off of deltainfo.ro
Which copy of the iso should I be using?
Old Nov 13, 2008 | 03:50 PM
  #364
HHH356's Avatar
Just did mine. Took a couple of mins and worked like a champ.
Old Nov 17, 2008 | 09:04 AM
  #365
Jie-EVO's Avatar
which link did you download the file from and which did you use ,,
thanks
Old Nov 17, 2008 | 11:15 AM
  #366
HHH356's Avatar
http://www.mitsubishiforum.com/m_222824/tm.htm
This is the one I used. no problems. It is for 30.94. to check hold down set and nav till the menu comes up and push the button that says "version information" at least that is what I think it is. Burn the iso to a disk pop it in, you will get a box that say update. Do it and then you will be good to go.
Old Dec 3, 2008 | 02:26 PM
  #367
ZK's Avatar
ZK
I downloaded the one for 20.68 and it worked for mine... Somehow the 30.94 doesn't work for me.
Old Dec 4, 2008 | 09:18 AM
  #368
HHH356's Avatar
You just need to hold down set and navi buttons at the same time for 3 seconds to get the hidden menu. From there you can see what software version you have so you know what file you need to use.
Old Dec 6, 2008 | 06:11 PM
  #369
navidf's Avatar
whatever happened to this hack for 30.97 versions MRs?
should we give up on this?
Old Dec 8, 2008 | 10:49 AM
  #370
KGHtheII's Avatar
+1
OtakuTTA can you comment on this?
Old Dec 14, 2008 | 05:01 PM
  #371
OtakuTTA's Avatar
Hrmm..
No, you shouldn't give up on this..
I'm no longer doing individual version patches.
I have created a gui to allow you to customize and patch various things in the unit..
Release should be shortly.
atb.
O.
Old Dec 14, 2008 | 06:42 PM
  #372
Rguy's Avatar
awesome news.
Old Dec 14, 2008 | 10:46 PM
  #373
navidf's Avatar
Wonderful. OK then, I will continue to wait
Hrmm..
atb.
O.
Old Dec 16, 2008 | 05:20 AM
  #374
stokEd's Avatar
Hrmm..
atb.
O.
Wow, that's sounds pretty cool.
OT: How have you been interfacing with the MMCS?
Old Dec 16, 2008 | 06:15 AM
  #375
razkal's Avatar
Sounds like we will probably have to pull the harddrive out. Hopefully the GUI is Mac compatible ;-)
