DVD Hack for the MMCS
Old Sep 15, 2010 | 01:35 AM
  #601
StreetGasm Maus's Avatar
Guys,
is someone able to help me out, i have a 2010 Evo and would like to have the dvd in motion patch
my version is BLD-NR-261EM 1.09
00.31.06
If possible i would have the whole system updated too but i dont know if that is possible
HELP please.
i also have a mac and use Toast it to burn cd / dvd
Thanks in advance
Old Sep 16, 2010 | 04:27 AM
  #602
solved for me
Old Sep 16, 2010 | 06:51 AM
  #603
bmanuhutu's Avatar
solved? how can you tell me which ones to download i need to unlock my 2010 x as well
Old Oct 8, 2010 | 07:37 PM
  #604
racingguy13's Avatar
Do these hacks work to allow both DVD and AUX to play video while moving or just DVD?
Old Oct 9, 2010 | 01:08 AM
  #605
So still no 41.02 patch yet? Seems it was stopped right before my version
Old Oct 9, 2010 | 07:25 AM
  #606
Enjoi's Avatar
Originally Posted by JohnnyBoy427
+1 If you're not smart enough to know that you can't watch a movie and drive at the same time you probably should be locked up under supervision at all times.
+1 for you good sir!
Old Nov 4, 2010 | 02:30 PM
  #607
bigjay10's Avatar
BUMP! I want this hack so bad. I have same version.
Old Nov 4, 2010 | 05:05 PM
  #608
Bump again as well.
Old Nov 4, 2010 | 06:21 PM
  #609
gatsu's Avatar
got this working on my 08 X
great stuff!!
Old Nov 9, 2010 | 11:11 AM
  #610
mrniceakap's Avatar
Hi all
I have a problem with my mmcs. Things I have done:
- Downloaded the following file:
http://rapidshare.com/files/38801905...4011.NODVD.ISO
- Burned it and put it in my mmcs
- Pressed "yes" on the display
- The mmcs restarted and I got the following message:
"The HDD doesn`t work. Turn off the ignition key and try again"
- I took out the CDRom and turned on the mmcs again, then the message "Insert Program Disc" appeard.
- Every Time I tried it with the iso/cdrom again, I got the same message "The HDD doesn`t work...."
- I put the HDD out and linked it with the pc. Then I realized that the HDD was dead. (Don`t spinning anymore)
- I took another HDD, restored the ghost image and tried the same process again. No luck, same message.
- Could someone tell me where the problem is?
- Could it be, that the mmcs is not able to lock a "unlocked" HDD in this state. (Not booting, just give this message)
- How can I lock the drive manually?
- Should I try a "Cold Boot"? (unplug battery for some time)
Hope you can help me, it drives me cracy.. Thanks
By the way, the mmcs sw infos:
SW-Version: F
MapVersion: 2006-1
CDDB-Version: 0663-0000
Loader: BLD-NR-261EM 1.09
Application: 00.31.06
Navi Sub Microcomputer: 00.30.00
Audio Microcomputer: 00.30.00
Map Data: M110 AEU_07_200701B
Monitor: 00.27.00
CAN Box: 000120
Best Regards
mrnice
Old Nov 16, 2010 | 04:16 PM
  #611
wrxnevox's Avatar
i got mine dvd hack and its working fine thanx to all
Old Nov 16, 2010 | 06:34 PM
  #612
HR2L's Avatar
Im having issues as well getting my MMCS to read the cd. I burn the .iso properly to a cd-r (with an iso recorder) but when I put it in it begins to read and then tells me to check the disc. Can someone link me to the proper file for USDM MMCS for v 30.94.
Old Nov 17, 2010 | 12:52 PM
  #613
mrniceakap's Avatar
I give up now... Tried over 2 weeks everything i could...
Seems that my mmcs is ****ed up. Damn it!
Old Nov 30, 2010 | 12:02 PM
  #614
flipflop's Avatar
great stuff!!
where's the link to download? I been searching for it and cant find it through the thread.. I'm freakin blind! thanks in advance
Old Dec 8, 2010 | 10:25 AM
  #615
EvoX5spd's Avatar
4011 is the last one? No one has created an updated ISO with a newer MMCS firmware version?
