Toruble reading mp3's
Old May 22, 2008 | 08:40 PM
tsitalon1's Avatar
Anyone else have trouble reading mp3 disc's with more than like 5 songs on them?
I am using HP CD-R 700mb disc's and after 5 mp3's on a disc it starts to not be able to read the disc...I get no errors on the screen, it simply gives up.
Old May 22, 2008 | 09:44 PM
kidneythief13's Avatar
are you burning the discs as data files?
Old May 23, 2008 | 01:33 PM
tsitalon1's Avatar
Yes, data file with all mp3's in root of disc. If I place more than 5 onto disc, you can hear the NAV unit trying to read for like 1 min..then gives up.
Old May 23, 2008 | 01:54 PM
Taryon's Avatar
Hmm, I don't think it shouldn't matter if it's burnt as a Data Disc or MP3 Audio Disc. I've done both with full capacity (wasted many CDs testing out the file folder structuring when I could have just looked at the manual) and they've both played perfectly.
Do these CDs you're burning only contain MP3s? and do they play fine on other MP3-CD players (or your computer media player even)?
Old May 24, 2008 | 07:34 AM
tsitalon1's Avatar
They plain fine on my computer, do not play on a cheap $25 cd/mp3 player....
I am leaving the session open (to be able to add more later) maybe this is the reason. Is your session open or closed once you take it to the car?
Old May 24, 2008 | 08:31 AM
srcevo8's Avatar
It has to be closed for anything other than you PC to read it. If you close your session then the disc should play fine.
Other than that, the only issues I've heard from most HU's is that when you have too many folders things can freak out. But since you're putting the files in the root then it's your open session that the nav can't read.
Old Jun 22, 2008 | 01:21 PM
makeithandle's Avatar
did you try shaking it violently then hitting it, that always works for me
Old Jun 22, 2008 | 06:03 PM
Ferraritech's Avatar
+1
Old Dec 22, 2009 | 07:57 AM
beyonddc's Avatar
Anyone still hitting this problem?
The MMCS sometimes has difficulty reading some MP3s on my MP3 CD. About 3/4 is not readable by MMCS and 1/4 is readable by MMCS on a single MP3 CD.
The error I received is something along the time "Play is impossible, eject the disc".
So far I tried the following
1) Replaced my DVD/CDRW Burner
2) Tried 3 different brand of CD-R
3) Used a different computer to burn the MP3 CD
None of these seems to be working
Old Dec 22, 2009 | 08:53 AM
total0wnage's Avatar
i have no idea why it wont work because it works for me but i suggest closing the session like someone else said and maybe try burning with a different program, i use nero
Old Dec 22, 2009 | 09:41 AM
beyonddc's Avatar
I use Nero also. I don't use multi-session and I always finalized the disc after burning.
Old Dec 24, 2009 | 10:33 AM
beyonddc's Avatar
Apparently, my problem is solved. It is not related with my DVD/CDRW burner or the software I'm using. It is related with the bit-rate of the MP3. Although MMCS advertised that it supports variable bit-rate but I guess sometime it doesn't. I'm not sure why's that.
What I did is I converted every MP3 that I plan to put on to CD from VBR (Variable Bit Rate) to CBR (Constant Bit Rate).
The software I used is WinMP3Packer which is freely available. For more information visit below website.
http://wiki.hydrogenaudio.org/index.php?title=MP3packer
Old Dec 25, 2009 | 10:07 PM
Nice find, that's good to know for future
Old Dec 28, 2009 | 11:22 AM
Webman's Avatar
This is the reason. Never leave the session open or place more than one session on each disc.
Also, the stereo is capable of reading VBR files. I've never had any issue with them.
SRToad4
Feb 21, 2013 10:34 AM
daniel_f_us
Jun 11, 2011 07:00 PM
vassili
May 21, 2010 11:01 AM
UCB
Mar 31, 2009 04:07 PM
jem designs
Dec 26, 2007 02:54 PM
