Looking to put music on my nav
Old Jan 19, 2009 | 02:28 PM
qu evox's Avatar
Hey all,
Im wondering if you guys think there is any way to pull out the stock HDD and then load music onto it by hooking it up to a computer. I have pulled harddrives out of numerous laptops, desktop pc's, and then hooked them up to other pc's to look through them. any shot you think this will work and that the nav will recognize the music after i get it all in there?
Old Jan 19, 2009 | 02:53 PM
Rguy's Avatar
You could possibly do this after unlocking the harddrive... it's a lot harder than just hooking it up to your computer.
Old Jan 19, 2009 | 03:09 PM
qu evox's Avatar
thats stinks and is weird. So your saying that mitsubishi has some sort of eccryption on the hd? and i wonder if and how long it will take before one of the harddrives craps out.
Old Jan 19, 2009 | 04:25 PM
Papi4baby's Avatar
Burn it to a CDRW and enjoy.
Old Jan 19, 2009 | 04:27 PM
qu evox's Avatar
yea i know you can burn it to a cd but i wanted to be able to transfer over like 4 gigs worth of music in a matter of minutes. lol. Idk i may pull the HD out and i guess be one of the first to try it this way? we will see how it goes....
Old Jan 19, 2009 | 04:28 PM
LancerEVA06's Avatar
The hard drive has encryption due to the fact that it's licensed software for the Nav. Good luck with actually putting music on it and being able to play it; there's no code in the O/S to play music from the hard drive.
EDIT: bad wording... there is no way for the O/S to play your transfered music... only through it's own software.
Old Jan 19, 2009 | 06:24 PM
KGHtheII's Avatar
Originally Posted by qu evox
Hey all,
Start Here: http://www.mitsubishiforum.com/m_208034/tm.htm
Old Jan 20, 2009 | 07:32 AM
goofygrin's Avatar
The issue is that when the music is ripped off the CD it's put onto the hard drive in a non standard format. So just dropping MP3s or WMAs (or some other format) onto the hard drive isn't going to fly. It's also possible that the files are indexed in a database (or flat file of some sort) and you'll need to update that index.
You'll need the tiny torx screw driver to get the hard drive out and then you'll need the unlocking bootable CD and the key from one of the mitsubishiforums threads (and the code is different depending on your version). Once the drive is unlocked, you'll be able to look at the contents and you'll see the files that the navi has pulled off of music CDs on there (among lots of other stuff). People have tried dropping music on there before without success.
I bet it can be done... it's just a matter of making it work. Maybe Otaku is working on it?
Old Jan 20, 2009 | 10:01 AM
qu evox's Avatar
yea im sure its going to be weird to do. But as soon as i can find a torx driver i am going to pull it and see what i can do. Putting music on it by each individual cd just takes so long and most times the names of all the songs dont show up and im just sick of the way they are all going in there. I will be sure to keep everyone posted on how it goes.
Old Jan 20, 2009 | 11:32 AM
goofygrin's Avatar
Lowes has a torx screw driver set for < $10 that has the one you need.
Old Jan 21, 2009 | 01:03 PM
jamdread's Avatar
It's easy to get to the hard drive unencrypted. The problem is that the Mitsubishi software doesn't read mp3's natively so if you drop mp3's on there, it won't do anything with them.
As stated previously when it rips a CD it stores the music in a proprietary format. figure out the format, convert your mp3's to that format, then drop them onto the hard drive and boom problem solved. Sounds easy, in reality . . . not so much
Old Jan 26, 2009 | 07:53 AM
qu evox's Avatar
ok well how hard/how do i get the hard drive unlocked once i remove it from my car?
Old Jan 26, 2009 | 08:22 AM
KGHtheII's Avatar
Originally Posted by KGHtheII
Instructions in the above url ^
Darunt
Mar 16, 2026 02:44 AM
sfb12
Lancer Troubleshooting
Jul 19, 2016 10:24 AM
stanrc
30
Jul 5, 2011 12:53 PM
dustyp34
Mar 13, 2009 04:36 AM
dhahlen
Nov 24, 2007 09:56 PM
