Metra MITO-02
Old Nov 16, 2009 | 11:47 AM
  #46
E6-X's Avatar
Originally Posted by mrMTB
Yes, the volume limiting issue seems to go away with an aftermarket head unit.
this is awesome news !!! does anyone has a link for mito-02 ?
need it desperately !
i'm planning to install kenwood dnx 7340 bt ... any comments on this unit ?
thx
Old Nov 16, 2009 | 12:24 PM
  #47
mrMTB's Avatar
Here you go... http://www.amazon.com/Metra-Electron...8403033&sr=8-1
Old Nov 16, 2009 | 12:52 PM
  #48
E6-X's Avatar
thxxxxxxx
Old Dec 6, 2009 | 10:33 AM
  #49
R3P5AJ's Avatar
will this connector work with this unit without the hassle of cutting/splicing wires?
http://cgi.ebay.ca/ws/eBayISAPI.dll?...%3DI%26otn%3D2
Old Dec 31, 2009 | 10:45 AM
  #50
cpunlamd's Avatar
I ordered the following to install my Eclipse AVN 6620 into my 2010 Evo X:
1. Scosche double din dash kit
2. Scosche wiring harness
3. Scosche MIAX (keeps AUX functional)
4. Metra Mito-2
My question is, will I need #2 and #3, if I already have the Mito-2? Just making sure I dont buy harnesses that I wont be using.
Old Jan 1, 2010 | 12:10 PM
  #51
MR Dan's Avatar
^^ I just installed my Alpine double-din unit last week with only the Metra Mito-2. You dont need any other adapters as long as your new headunit has front and rear preouts. I only had to crimp/solder the power, ground, and amp turn-on wires from my Alpine headunit harness to the Metra Mito-2 harness.
Old Jan 5, 2010 | 03:34 PM
  #52
ikt's Avatar
ikt
just ordered mine today, amazon has them for 109
Old Jan 31, 2010 | 01:58 PM
  #53
Jcusco407's Avatar
so is there no way to have the sub connected as its own channel to the mito?
Old Jan 31, 2010 | 04:07 PM
  #54
mrMTB's Avatar
No. The sub just runs off the signal going to the rear channel.
Old Feb 6, 2010 | 01:21 PM
  #55
cpunlamd's Avatar
Does anyone know if the stock blue tooth will be functional with an aftermarket head unit if we use the MITO-2??
-----> Just read it a few pages earlier. The factory blue tooth works with out any modifications, since it is not part of the head unit.
Old Feb 8, 2010 | 01:08 PM
  #56
Xenozx's Avatar
really, this is surprising, I would think it was part of the headunit. I know when I use it now in my 2010, the TN shows up on the headunit. So if I take the headunit out, I would think that would be lost?
Is there a way to disable the stock bluetooth, cause if I go w/ an aftermarket headunit, I would think I would want to use that bluetooth over the stock setup. Wouldnt having 2 make things confusing?
Old Feb 8, 2010 | 03:09 PM
  #57
mrMTB's Avatar
Yes, just unplug the interface box. It sits behind the passenger side dash piece. You access it with the glove box removed.
Old Feb 8, 2010 | 05:04 PM
  #58
Xenozx's Avatar
thanks, so it is confirmed, that factory bluetooth can be used, even if the stock radio is removed?
The controls (for making a call, hanging up, and answering) will still work? they are hooked to the interface box, not the head unit?
I guess on incoming calls, theres no way to know who is calling you since the # will no longer show up on the head unit since its been replaced?
kinda off topic, but can someone confirm if the SCOSHE dash kit will fit a 7 inch screen, or would I be stuck getting say a 6.5 inch screen?
Lastly, anyone who has done this, is there a noticable difference in sound quality? does it get rid of that auto volume limitation problem?
Old Feb 8, 2010 | 05:55 PM
  #59
Jcusco407's Avatar
A 7 inch screen will fit but if it has a motorized face it will not be able to open
Old Feb 9, 2010 | 06:43 AM
  #60
Xenozx's Avatar
so that means that you cant take the faceplate off? I want a HU that is like the stock rockford nav system for the evo. I dont want one that pushes out and sits up in a single din location.
Can someone answer the questions above if you have a chance?
