Fitting aftermarket sub in stock location?
Old May 20, 2009 | 02:53 PM
c_reber's Avatar
Well the stock sub is DVC .9 ohms each, so in series it is about 1.8ohms. But if you can get a 4ohm DVC at 2ohms, then you might be able to make the stock amp work on it. However, I would bet the stock amp pushes maybe 25-50 watts RMS maximum at 2 ohms. The stock amp is pretty weak...
I think the mounting depth in the stock enclosure is just under 4", maybe 3.75" or so.
Old May 21, 2009 | 07:08 AM
RedlineX79's Avatar
Originally Posted by salukidude
My bass is far from ridiculous (and I know what you mean by ridiculous). In fact, with the 150W to each door speaker, my bass is almost weak. I'm running 1 JL 10W6v2 on a 600W Alpine amp. If I had to do over again I would go with a 12W6v2 and a 1000W amp. The thick back seat cushion really deadens the bass. I think you will be hard pressed to get noticeably better bass using the factory subwoofer box. Good luck.
Originally Posted by EVOxStuntin2008
I would have to agree. I have a JL 10W7 with a 500 watt monoblock amp, and I really wish that I would have gone with a 12.
Jeeze... ok maybe i'll price out a custom box and see how bad it is.
Old May 21, 2009 | 06:13 PM
TwistedDreams's Avatar
A custom fiberglass box is going to run about $300 from what I've heard.
I think it's totally worth it, it looks so clean when it's all done.
-TD
Grimgrak
12
Nov 17, 2012 10:47 PM
joe636
22
Dec 14, 2010 07:48 AM
Xenozx
10
Nov 25, 2009 10:25 AM
Tonic25
Sep 14, 2008 12:24 PM
RyanEvo2006
Dec 28, 2006 02:43 PM
