prefab sub boxes
Old Sep 27, 2012 | 08:26 AM
Grimgrak's Avatar
prefab sub boxes
Pics of sub boxes i can order online for a 10 to fit in the trunk of an 05?
Old Sep 27, 2012 | 06:44 PM
igo4bmx's Avatar
audio integrations
http://www.audiointegrations.net/cat...79/4763874.htm
I have one for sale with sub.
Old Sep 27, 2012 | 07:29 PM
Grimgrak's Avatar
Your ad says it's for a 12 and I would need much better pictures installed zoomed out
Old Sep 28, 2012 | 11:28 PM
dizaryl's Avatar
http://www.wickedcas.com/gallery/v/magicboxes/EVO/
http://www.wickedcas.com/product.php...&cat=23&page=1
Old Oct 6, 2012 | 08:29 PM
hatesposers's Avatar
I have the wicked boxes in my Evo. They will work with both 10s and 12s.
I started with 10s, then upgraded to 12s by just cutting out the 10" ring and installed expanded nuts
Old Oct 6, 2012 | 09:23 PM
djslik408's Avatar
http://
Old Oct 10, 2012 | 03:55 PM
bluedevil500's Avatar
I would always go over the joints with additional caulk just in case.
Old Oct 12, 2012 | 02:35 PM
stryfetew's Avatar
djslik what type of sub did you get for your SSL box?
Old Oct 13, 2012 | 01:34 PM
djslik408's Avatar
i replaced the stock to an 8" Kicker.
Old Oct 24, 2012 | 11:01 PM
TA EVO's Avatar
thanks for the links..
Old Oct 25, 2012 | 06:28 AM
seanjohn291's Avatar
You could always make your own boxes! You can get the materials under $100 to build it instead of spending $350 each
Old Oct 25, 2012 | 08:19 PM
stryfetew's Avatar
Did you use a shallow mount or regular sized?
Thanks!
Old Nov 17, 2012 | 10:47 PM
OreOs's Avatar
Here is my custom box i just made myself, took about $100 in supplies to make and lots of time, but it sure beats paying a shop $500 to make one. And it suits my needs since i wanted it deep enough and strong enough to support my 10" w7. Its also ported, and i dont see many people porting their fiberglass boxes.......
It is 1.5 cubic feet, and has a 3" port tuned to 38 Hertz.
It also is one entire piece (one layer of fiberglass, from trunk lid rubber grommet, to sub box, to thin panel that covers the rear suspension, and upholstered as with one carpet) which I think gives it a much cleaner appearance,
And since it removes the factory carpeted panel, it takes advantage of the airspace wasted in other boxes where the quarterpanel is.
Veronica
Nov 19, 2024 08:54 AM
Chrispy0530
Sep 22, 2016 05:51 AM
dtmevox
Jan 2, 2016 08:18 AM
Kevin Koszarek
10
Oct 14, 2015 11:15 AM
max4rw
30
May 25, 2010 06:08 PM
