Quick: switched power and firewall help ( EVOX)
Old Oct 18, 2009 | 10:51 AM
thrlskr's Avatar
I need help with two things:
1. Where is the best spot to vampire tap a switched power line? Wire color? Photo?
2. Best spot to run cable to the engine bay? It needs to be large enough to fit a small phone cord plug. Pics or detailed location would be great.
9500ci instalation write up coming soon...
Old Oct 18, 2009 | 09:01 PM
►EvolutionX◄'s Avatar
Dont use vampire clips in my opinion, they can damage wires, use a fusetap available from kragen or the likes for 10 bux, maintains complete stock.
Search for the thread on boost gauge install, no drilling, theres a good place to run stuff. May I ask what you are running to your enginebay?
Old Oct 19, 2009 | 07:45 AM
thrlskr's Avatar
Thanks I'll search for that thread. I'm running wire for the radar sensor and laser shifters.
Old Oct 19, 2009 | 08:51 AM
MasterAK's Avatar
I have described two possibilities in these threads:
The locations should be identical on the evo as well.
Passenger side
STEPS 7-8
Drivers Side
Old Oct 19, 2009 | 09:45 AM
goofygrin's Avatar
The easiest switched is the cig lighter. Just pull the shifter plastic and it's right there like a juicy vein (you started with the vampire talk ).
Old Oct 19, 2009 | 09:55 AM
MasterAK's Avatar
Even easier is to take power from the cig lighter fuse. Eliminates the need to route the wire to the cig lighter. Use "add a fuse" kit for a clean installation.
neverboosted91
Jun 7, 2011 09:34 PM
EvoDan2004
May 2, 2010 12:46 PM
BerserkerX
Nov 15, 2009 01:34 PM
Werd
Jul 4, 2009 06:04 AM
RyeLou
Feb 15, 2009 05:45 PM
