factory nav aftermarket amp
my nephew had a lancer with rockford fosgate navigation and traded it for evo with aftermarket navigation which didnt work very well so i swapped them now he bought an amp and sub box but no rca outs what are my options
thanks in advance
thanks in advance
you can get a line converter to splice into your speaker wires and it will have rca connections on it. This is not the optimal way to do things, but it will give you the end result you need. I did this to my lancer with stock head unit in it too, not the nav. system tho. Should work the same way. I had to run my remote wire from my amp into my fuse box tho as there is not remote line on the back of the radio
Prasse
Sep 16, 2015 06:45 AM
Eckolistik
29
Jun 9, 2011 06:10 AM
08MitsubishiGTS
Feb 10, 2008 11:47 PM
