need help wiring alpine pdx5 into rockford system
Old Sep 9, 2010 | 12:26 PM
TJs98GT's Avatar
I just got my alpine pdx5 and crossovers in today but i dont know how to wire the factory system inputs into this amplifier since it has RCA inputs. any suggestions? Do i use LOC on certain wires?
also, which wire did you use for the remote wire? im sure i can tap right into one of those. i have all the wiring diagrams in alldata but im not too good at reading electrical diagrams
Old Sep 10, 2010 | 04:21 AM
TJs98GT's Avatar
bump!
Old Sep 10, 2010 | 01:54 PM
Greedy_son's Avatar
Im not sure about the wiring into the rockford amp but the remote wire will have to be from a ignition key source. The Rockford uses a canbus system so it doesnt need a remote signal to turn on.
Old Sep 10, 2010 | 08:58 PM
AFD's Avatar
AFD
Originally Posted by Zeroflux
The line out from the deck is a low level output so you just need solder on some RCAs and it will work with any Amplifier.
Found that info from this thread, which should help you out alot..
https://www.evolutionm.net/forums/ev...d-oem-amp.html
Scroll down to the 4th post for pix and wiring details.
..and good luck!
JDMV8
Apr 8, 2015 08:25 AM
dbsears
10
Aug 25, 2013 01:58 PM
mogace
Sep 4, 2010 10:49 PM
mr.green
Jan 6, 2009 12:56 PM
VRSF Tiago
Jun 19, 2008 10:14 PM
