Scosche vs JDM double din kits
Old Jun 14, 2011 | 10:21 AM
  #46
AFD's Avatar
AFD
Dunno.. I just checked the Eclipse AVN6620 chassis size against an Alpine INA-W900BT (which does fit)..
Eclipse: 180 x 100 x 165 mm (W x H x D)
Alpine: 178 x 100 x 160.5 mm
Kenwood: 181.7 x 100 x 180 mm
Pioneer: 178 x 100 x165 mm
Don't think that 5mm extra in length will matter much, since you'd need additional space for stuffing wires behind the unit.. and the 1mm extra per side might just be a slight difference in where the two companies were measuring from.
Dumb question, but I saw in the manual that the AVN6620 comes with rectangular shipping brackets screwed into each side.. you removed those right??
Only other thing I saw in the manual was mention of using either the included red M5x8 hex bolts OR the red M5x8 flat head screws.. I could see the hex bolt head maybe causing a clearance issue or something weird.
In any case, lots of luck!
EDIT: Added chassis dimensions of Kenwood DNX9980HD and Pioneer AVIC-Z130BT / X930BT for comparison.
Old Jun 14, 2011 | 05:01 PM
  #47
JDMCT9MR's Avatar
Finally got the scosche kit to fit correctly. I took it to a local stero shop and the guy had to make a few mods to the bracket and now it fits like a glove! Thanks for all the help!
Old Jun 14, 2011 | 09:30 PM
  #48
sicknt760's Avatar
For the easability of getting the item I would def say that Schosce would be the way to go. Now if you could find a good deal on a JDM dash kit jump on it quick before its gone cause they are hard to find.
Old Jun 15, 2011 | 08:42 PM
  #49
AFD's Avatar
AFD
Glad to hear you finally got it sorted out!
Old Jul 12, 2011 | 01:12 PM
  #50
eGadz's Avatar
Nice happy to hear it all went well in the end
Old Jul 13, 2011 | 12:47 AM
  #51
JDMCT9MR's Avatar
Thanks man for all the help!
Old Jul 29, 2011 | 02:39 PM
  #52
limx's Avatar
Hi, where can i buy the JDM dash kit, I know that japanparts, but any other site in US?
LimX
Old Jul 29, 2011 | 02:42 PM
  #53
BravoZero's Avatar
Had a Kenwood nav unit installed today, using the Scosche kit. It's not perfect, but it's pretty damn good. There's a spot in the top right corner where the plastic sticks up a bit over the dash, but nothing a Xacto knife can't fix.
Old Jul 29, 2011 | 04:28 PM
  #54
sicknt760's Avatar
I waited around for a while cruising the forums until I found a JDM kit a little more costly than the Schosce, which would have been my second choice. The JDM is much cleaner and a for sure fit without any modifications.
Old Aug 2, 2011 | 09:25 PM
  #55
yellowdennis's Avatar
so jealous of the dd, too bad orbital stopped making it for the viii/ix
bhaikalis
Feb 5, 2016 05:35 PM
racespad3
Nov 12, 2015 03:09 PM
dragon831
May 19, 2011 06:44 AM
kamote24
Feb 14, 2010 08:04 PM
lancer0220
12
Oct 16, 2008 06:23 AM
