Aftermarket Nav for EVO X MR with Premium package?
I've heard stories of aftermarket navs not playing well with the premium Rockford Fosgate amp. Is this still true? The dealer is suggesting I go aftermarket, but what will I give up by doing so? Thanks!
i have a Pioneer aftermarket head unit that replace my fosgate package...my sub still works and everything else. The Pioneer unit has built in navi, everything works fine...i have the GSR SSS. Had it installed though, so maybe they knew what they were doing.
I am pretty you can get to all those functions through the on-board computer in the dash (between the tach and speedo). The Nav unit just makes it easier.
Nope, you need a MUT III in order to be able to access the ETACS functions without the factory navigation system. If you replace the nav (or didn't have it to begin with) you'll have to take it to the dealer to change those setup options.
would you need the dealer to do this or can we do it ourselves?
I see how what I wrote might have been vague...
The factory navigation system communicates with the ETACS over the CAN. Once hooked up, you will have access to a menu grouping that allows you to access certain settings within the ETACS (unlock the driver door on first unlock - all doors on second, or all doors first unlock; tapping the turn signal gives one or three blinks, etc). It is my understanding that the NAV system does not need to be married to the ETACS.
The display in the dash, known as the multi-information display or MID, does not have access to these functions within the ETACS. If you do not have the MMCS in your vehicle, the only way to access these functions in the ETACS is through the MUT III - found conveniently at your local dealer.
Here's a nice writeup on the ETACS and how it works...
http://www.mitsubishi-motors.com/cor...006/18e_14.pdf
I don't have any documentation on the options that are available for us within the system, but the above PDF makes reference to what some of them might be.
Metra's MITO-02 is your answer. It gives you control of the RF amp/sub with your aftermarket unit. As previously posted, ETACS does not have to be connected for everything to function, but you'll also lose control of the functions related to ETACS. Some of them, however, like the FAST key functions, you can alter by using some sort of contra-cheat-code like combo with the door open/close combination or something. So it's not like you'll lose EVERYTHING, but if you don't know about the ETACS, it's very unlikely you'll miss it anyhow.
BUT, if you haven't read already, MITO-02 aren't exactly without its own issues...so it's a risk in itself.
Camoevox. Can you verify you still have access to your cars settings?
Can MUT-3 still access ETACS if the new head unit is disconnected? If so, where does it plug in?
djdanrt
Outlander Sport
Sep 12, 2015 05:56 PM
sgtboost
Oct 27, 2012 08:03 AM
sgtboost
Sep 28, 2012 06:34 AM
