OEM Navi In-Motion Bypass
Old Jun 12, 2011 | 09:48 AM
AFMedic55's Avatar
Question OEM Navi In-Motion Bypass
Hello, I have done some research on the in-motion bypass for the factory installed Navi unit. I found several different posts that said a CD could be burned and upload a patch directly to the unit without splicing wires or taking anything apart. All of the links seem to lead to :
http://www.deltainfo.ro/manuals/mits...MMCS-E-DVD.rar
Unfortunately, this link no longer seems to be active. Is there a different fix that I am not finding? Any help would be greatly appreciated! (I did use Google quite a bit )
Old Jun 16, 2011 | 09:00 AM
AFMedic55's Avatar
I don't want to watch Inception driving down the freeway, it's for my wife when we travel on leave.
Anyone?
Old Jun 16, 2011 | 11:14 AM
Orinux's Avatar
I did a nav install in my old car. I remember bypassing the parking brake safety feature. If it has an internal gyro, you have to get a little more creative with some surface mount soldering. Burned cd to patch it? Never heard of this.
Old Jun 16, 2011 | 01:34 PM
armysoldier1073's Avatar
https://www.evolutionm.net/forums/ev...hack-mmcs.html
i did the hack and found how to do it here. you have to use an ISO burn program to use the hack... also it will show you how to find your version number.... unfortunatly the new versions probably wont be done, due to lack of time needed to "hack new versions"... if you find a hack for your version software, it is too easy.
Old Jun 22, 2011 | 03:45 AM
paul123's Avatar
From what I've read in various forums, there are no hacks for versions 00.41.02 and above.
If you hold down SET and NAV together for a few seconds, you'll get another menu where u can select VERSIONS INDICATION. Within that, look for your APPLICATION version. If yours is below 41, there should be a software patch for you.
Good Luck!
Timothy Kramer
Oct 8, 2016 11:32 PM
Nicker31
Jan 20, 2016 02:48 PM
Treyzian
Dec 20, 2015 10:21 AM
Al-Mannai
Evo X How Tos / Installations
Mar 27, 2012 08:30 PM
Landshark
Aug 11, 2011 12:28 PM
