Increasing Brightness/Height of HID?
Old Aug 29, 2011 | 02:27 AM
HDGamer's Avatar
Hey guys, I'm just wondering is there any way to increase the brightness or height of the stock HIDS? The leveler is currently set at 0, which is the highest, and I'm not too satisfied with how high up the HID's go. The brightness isn't all that impressive either, my girlfriends PNP kit is actually brighter and higher than the EVO x's. Right now I feel like the stock HIDs are no brighter nor cover a larger range than my old Halogens on my Civic.
Will going in and adjusting the level using the screwdriver help? Is there anyway to change the "Bulb" of the HID out for something brighter? If so, what do I need?
Old Aug 30, 2011 | 12:33 AM
AFD's Avatar
AFD
Adjusting with a screwdriver should help a little, if you can get to it.. and you should be able to change the bulbs out to something in a different color temperature (ie, more yellowish or more bluish), but I'm not sure if that would actually help at all. And make sure the outside of your headlight assembly is nice and clean.
I'd just try raising the aim up a bit more 1st. Here's a schematic for that..
https://www.evolutionm.net/forums/9557796-post12.html
And if all else fails, just add a lightbar
Old Sep 4, 2011 | 10:58 PM
Finest's Avatar
I love my HID's, it's a world of difference from other cars I've driven with HID's. Plenty of brightness and height, I've had cars flash me on the hwy if I had it set to the highest. (then I'd get mad and REALLY high beam them blind!)
Did you do anything to your headlights recently? Maybe they're not aligned or leveled properly.
Old Sep 4, 2011 | 11:05 PM
vboy720's Avatar
you can upgrade to 50w ballast and bulbs for brighter lights.
Old Sep 4, 2011 | 11:10 PM
prowakeskater's Avatar
+1
I have 55w hid's in my 600rr and its unreal. makes people very aware of me
Old Sep 11, 2011 | 09:20 AM
JTTME's Avatar
+2 55w ballasts and stay away from any HID bulb that's above 6000k, 4300 give a nice blue but white output of lights, it's the brightest temperature by far.
Old Sep 13, 2011 | 03:24 PM
Rog96's Avatar
mine seem alil low so i took it to the dealer and they said everything is fine so i just got used to it and btw i want a light bar they look good
rodent
Feb 23, 2015 08:49 PM
krazydan19
Jul 7, 2014 08:35 AM
kyoo
Apr 17, 2014 06:29 AM
nobodyphil
11
Aug 15, 2011 12:15 PM
