Climate control illumination not working
Old Jan 6, 2015 | 08:42 PM
Sknakaction's Avatar
I can't seem to figure out why the climate control gauges are no longer illuminating light they work and the lights come on when I push the AC in when I push the rear defrost but they're complete black besides that does anybody know of a tab two previous post it so if you could point me in the right direction that would be helpful thanks also I checked fuses and there wasn't any shorted that I could see
Old Jan 10, 2015 | 12:53 PM
jakeleclair2000's Avatar
Do the obvious things first -
Check fuses
pull panel and check connections - make sure all plugs are securely attached and that you don't have any bent pins
If that doesn't fix it you have 2 options
replace the panel
get the EVOX wiring schematics and a DMM and start testing.
Old Jan 15, 2015 | 11:28 AM
Veronica's Avatar
Take the unit apart - it may be a loose connector inside.
(I had to when I swapped out the board for a board with the 'spiffy blue/white lights' to match the new headunit and OEM dash...)
ooSupergirloo
Jun 16, 2013 07:44 PM
shadovarian
Apr 12, 2013 11:08 AM
SteVenQDZ
For Sale - Miscellaneous Automotive
May 7, 2008 10:34 PM
