Fluttering sound after tune.
Old Jun 30, 2008 | 09:22 PM
SpeedI2acerX's Avatar
bump for any more suggestions? im still having this problem. im might just go ahead and grab the ebc from perrin. now how would it work with the re-flash? since the reflash controls boost? the dude at Works said i dont need mbc anymore...but i would be installing an ebc.
Old Jun 30, 2008 | 11:51 PM
nj1266's Avatar
Everyone is telling you that it is OK...It is not a problem. The Works flash comes with a boost control hose that has a more restrictive than stock pill in the boost line. DO NOT add an EBC or MBC to the Works flash. There is absolutely no need for it. You already have ECU boost control with the Works flash.
Old Jul 1, 2008 | 08:18 AM
mrfred's Avatar
A better diverter valve is probably needed.
Old Jul 1, 2008 | 08:26 AM
well its sure annoying. what i dont get is why did it happen after a long trip? worked good for 1 week. can the re-flash change it self to cause this problem?
Old Jul 1, 2008 | 08:50 AM
06ravenmr's Avatar
get an ebc and stop controling boost thru ur ecu..
Old Jul 1, 2008 | 09:35 AM
mrfred's Avatar
The stock boost control system is an EBC. You must mean a stand-alone EBC. How is a stand-alone EBC going to solve the flutter? Run less boost?
Old Jul 1, 2008 | 09:43 AM
06ravenmr's Avatar
yes a standalone ebc. i had nothign but problems using the ecu to control boost. i would say maybe the diverter valve like u stated before but the op stated it was fine for about a week then it all started happening. its def a tuning problem in the ecu.
Old Jul 1, 2008 | 10:09 AM
mrfred's Avatar
The built-in EBC in the ECU is fine. Its not going to affect any tendency for the turbo to surge if its tuned properly.
The stock DV on my IX gets a bit sticky in the winter months causing my engine to flutter in the morning. Granted this isn't winter time, but DVs can have problems. I'd say a first good step would be to pull the stock DV, check it, and clean it. I'd also suggest checking the vacuum line going to the DV.
Old Jul 1, 2008 | 04:36 PM
nj1266's Avatar
ECU boost control is not for everyone. It is not easy to set-up properly. But once you get it right, it is a thing of beauty.
Old Jul 6, 2008 | 01:23 PM
arbo651's Avatar
My car has never been tuned and it does it. this is normal.
Old Jul 6, 2008 | 02:08 PM
AutOtaku's Avatar
it's not good for the turbo in the long run but it sounds hella nice
Old Jul 6, 2008 | 02:21 PM
~BoOsTeR~'s Avatar
As Sti2ExoX said, he upgraded the solenoid and did not add a controller. I think you have the two confused.
Perrin sells the EBCS - Electronic Boost Control Solenoid, not the EBC - Electronic Boost Controller.
Old Jul 6, 2008 | 07:41 PM
glad to hear. its not just me but...
...that alone does not sound good. why is it not good for the turbo?
so if i want to upgrade my solenoid. the one from perrin is ok?
Old Jul 6, 2008 | 07:47 PM
Jeeperjunior's Avatar
I got the greddy profec B spec II ebc. It works wonderful. I have had zero problems.
Old Jul 6, 2008 | 09:01 PM
eXstasy's Avatar
.. its been a week after i got my tune. everything went fine but today i notice a lot fluttering sound at low rpms. seems like when boost is building up. not doing it when im driving normally. actually ive been noticing it for while but didnt think nothing of it cause it happens at low rpm. for example when at on 5th gear and i floor it at 3-4k, it flutterings. normal?
Sounds like wastegate flutter to me. I don't know why everyone is talking about compressor surge. Compressor surge happens when you lift off the throttle and you are under boost and do not have a BPV/BOV to vent the pressurized air.
