Real-time data logging?
Old Nov 3, 2008 | 05:56 PM
xbox4414's Avatar
Are there any real-time data loggers out that we can use on the X? I've been hearing about PCMSCAN but I don't feel like paying for a license at this time. Are there any other programs we can use, possible shareware programs such as ECUFlash?
Old Nov 3, 2008 | 06:39 PM
SiC's Avatar
SiC
None that I know of......
I'm interested in a logger that can log knock & load on this new CAN system. I wouldn't mind paying for a good logger.
Old Nov 3, 2008 | 06:47 PM
dkstas's Avatar
Just a noob question, but if knock and load are ecu parameters, shouldn't a scanner such as my LM-2 be able to read this? I'm still tinkering with it.
Old Nov 3, 2008 | 06:56 PM
xbox4414's Avatar
Well the Dashhawk logs load and such but not knock and not real time. It's records it and I can play it back....
Old Nov 4, 2008 | 01:24 PM
08EvoXGSR's Avatar
DashDaq from DrewTech-no knock-but can work with the zietronix WB O2. Worked great for me-logged 9 dif parameters at once (RPM, Thrtl pos, load, MAF, MAP, intake temp, front O2 (not WB), coolant temp,and I cant remember). My $0.02. I think there are a couple other tuners on here doing the same.....plus it'll read/clear codes, ect. Great device-using it on the MBZ now as well.
Old Nov 4, 2008 | 01:59 PM
xbox4414's Avatar
Sounds a lot like Dashhawk. So it real-time datalogs to a laptop? Does it do boost? And ashame it doesn't work with the AEM o2. Shareware? Sorry, work limits my internet acess.
Old Nov 4, 2008 | 02:05 PM
pltek's Avatar
evoscan will shortly
Old Nov 4, 2008 | 02:10 PM
Rguy's Avatar
evoscan, i wants it.
Old Nov 4, 2008 | 05:27 PM
Luis@TTP's Avatar
This is correct!
We are a stocking dealer for DashDaq.
Old Nov 4, 2008 | 06:18 PM
xbox4414's Avatar
^ Um ya no thanks. That's the complete opposite from what I'm looking for...
Evoscan looks promising... Any word on X support?
Old Nov 4, 2008 | 07:00 PM
quickgti18t's Avatar
Is evo scan anything like ross-tech(http://www.ross-tech.com/index.html).. I want something like this for the X.. I mean on my VW/Audi i can log anything possible on can-bus system....
Old Nov 5, 2008 | 01:23 PM
xbox4414's Avatar
So are there ANY programs out to monitor real time? Does PCMScan data-log for the Evo X? I can hold off on adjusting timing maps if I can't watch knock. But I would like to watching AFR's with my AEM UEGO and boost real-time. Anyone have ideas?
Old Nov 5, 2008 | 01:57 PM
RazorLab's Avatar
PCMScan does not log knock. It does however log timing, temps, boost (with a 255 kPa absolute cap), maf, IAT, ECT, etc etc
Old Nov 5, 2008 | 02:15 PM
xbox4414's Avatar
So does dashhawk. May not be instant on a data-log....but dam close. And with it's real-time display and warning lights I can set...I'll use that for now till something is released for us and for knock.
Old Nov 5, 2008 | 02:40 PM
RazorLab's Avatar
Yea if you already have something that works well for you, then by all means...
Sample from a datalog I've taken with PCMscan:
