Cobb Tuning Access Port Is Now Available For The Evo X!
Old Nov 27, 2008 | 01:00 PM
  #46
Web9's Avatar
Will the Accessport Stage 1 Stock Map work with an EBC installed or does it need the stock solenoid hooked up?
Old Nov 27, 2008 | 02:23 PM
  #47
DynoFlash's Avatar
It will work fine with the EBC just use stock boost level and do not try and run more boost than stock levels
Al
Old Nov 27, 2008 | 04:32 PM
  #48
Dr..Evo's Avatar
Will the ap overwrite an ecutek flash? Just asking b/c I heard an ecutek flash puts some sort of lock on the ecu.
Old Nov 27, 2008 | 05:06 PM
  #49
Rguy's Avatar
ecutek does not lock the ecu on the X's.
Old Nov 27, 2008 | 07:24 PM
  #50
pltek's Avatar
i would not run ap with ebc. cobb likes to use stock system to control boost
Old Nov 27, 2008 | 09:17 PM
  #51
Web9's Avatar
Al
ok... so which is it? stock or ebc with stock psi max?
I have a GReddy Profec B Spec II, but don't go over 23 psi max.
Old Nov 27, 2008 | 09:42 PM
  #52
DynoFlash's Avatar
Boost is boost - as long as you run the same boost as the desired target of the intended Cobb map then you will be fine using a EBC or MBC
Al
Old Nov 27, 2008 | 09:43 PM
  #53
DynoFlash's Avatar
I am not sure on that one myself
I am unsure what security protection is built in
Old Nov 27, 2008 | 09:45 PM
  #54
DynoFlash's Avatar
Not sure on that one.
On the Subaru Cobb and Ecutek coperated from years 2002 - 2007 so they share the codes and an Access Port can overwrite an Ecutek reflash
On the Evo products thus car it has not been an issue as neither was locked
The Evo X has a few loose ends we will be sorting out soon
Al
Old Nov 27, 2008 | 09:46 PM
  #55
Rguy's Avatar
Ecutek maps can be downloaded from the ecu no problem.
Old Nov 27, 2008 | 11:20 PM
  #56
Web9's Avatar
Al
Cool. Any idea what the desired target of the Stage 1 map is then?
Old Nov 28, 2008 | 07:57 AM
  #57
dcasandman's Avatar
So if this monitors boost do you really need a boost gauge?
Old Nov 28, 2008 | 08:08 AM
  #58
RallySport Direct's Avatar
Silver Sponsor
You can monitor your boost with the AP so you can use it to verify what psi you are at. That being said if you want to monitor it all the time VIA the AP you will need to have it always plugged in a find a way to mount it. Also you will need to go into the settings everytime to get to the gauges.
So if you are only going to look at it once in a while you could use it. If you want to have it be your gauge it is a little more tricky.
Old Nov 28, 2008 | 08:37 AM
  #59
dcasandman's Avatar
K, so I guess Ill still install my AEM boost gauge and wideband just to make it easy.
Old Nov 28, 2008 | 09:11 AM
  #60
Messidona's Avatar
Will this work with a JDM Evo X?
