Cobb Tuning Access Port Is Now Available For The Evo X!
Old Dec 1, 2008 | 11:54 AM
  #106
DynoFlash's Avatar
Originally Posted by EVO-IX-MR
That is what I needed to know, thanks!
Do you know if just replacing the stock boost lines with new ones that don't have restrictor pills will help the stock BS hold boost better? Vacuum lines can be picked up at a local auto parts store and installed in place of the stock ones pretty easily, that is why I ask.
Do the restrictor pills provide some type of overboost failsafe or something? If not, what is the point of them being there since actual boost can be controlled with the BS?
When we custom tune a car we use blank restrictor pills from Cobb and then use jet drills to find the best size
By altering the pill size we can effect the way in which the stock hose system works
Any time you alter the pills you would need a custom tune - UNLESS and limited to those situations where the Cobb base map specifies a modified pill size
When in doubt - review the map description that comes with every AP map that lists what mods and fuel the map is made for (a/k/a LONG DESCRIPTION)
Al
Old Dec 1, 2008 | 11:58 AM
  #107
Papi4baby's Avatar
I just placed an order for mine. Thank you to everyone that contributed to the info on this thread. I will post a mini review and pics when i get it, hopefully by here by Wednesday.
Old Dec 1, 2008 | 11:59 AM
  #108
RallySport Direct's Avatar
Silver Sponsor
like razor lab said the boost pills actually help with the boost and without them you will run less boost so you want to keep them in the system.
I have a feeling cobb will be offering the lines with the smaller pills and maps for them for their stg 2 maps. But no final word yet.
Originally Posted by DynoFlash
By way of update, I have ordered my initial stocking order from Cobb Today which will arrive tomorrow
All orders which I have recieved will ship tomorrow via fed ex
Through the x mass holiday I will continue to offer free overnight fed ex shipping on these, although my free map offer is now over
I will be tuning a couple of Evo X's with the AP tomorrow and will make a few videos
Al
Great I am excited to see some results on some real life cars
For those that need instant gratification we do have them in stock and can ship out today. Cobb has offered a 10% off deal so we will be honoring the 10% discount for now.
Old Dec 1, 2008 | 12:20 PM
  #109
EVO-IX-MR's Avatar
Thanks for all the answers on the stock boost lines and restrictor pills, much appreciated!
With a MBC restrictor pills of any type are not needed, correct?
I understand how the restrictor pills work now, but I guess it still doesn't make sense why they are needed with the stock BS if they are not needed with a MBC. Is the stock BS (in conjunction with the ECU of course) not capable of completely controlling boost on its own like a MBC is?
Old Dec 1, 2008 | 12:32 PM
  #110
Silver Sponsor
Christian from Cobb wrote something about this in his explanation on how the Subaru boost control system works. I think his explanation of it is better then I could write.
Changing the size of the center hole in the restrictor pill; the vacuum lines for the factory boost control system contain a small brass restrictor pill located in the short vacuum line coming off the turbo compressor housing. The middle of this restrictor pill has a lengthwise hole precisely machined to a certain specification so that it works with the factory wastegate actuator and the wastegate duty cycle settings in the stock ECU. The size of this center hole can be changed in order to mechanically assist boost control.
A smaller diameter hole in the center of the brass restrictor pill will have a higher tendency to create boost spike in the system and require less wastegate duty cycle to run higher boost. The larger the diameter hole in the center of the restrictor pill, the less chance the boost control system will boost spike and greater wastegate duty cycle will need to run in order to produce higher boost.
So you can see why the put them in there. A MBC does not need this because it is designed to not have them. The spring in it is designed to compress at certain pressures. You could make a solenoid work without a pill it would just be difficult and you would probably need to upgrade to a super heavy duty(read expensive) solenoid.
Old Dec 1, 2008 | 12:42 PM
  #111
EVO-IX-MR's Avatar
That makes sense now! Thanks for the 411
Old Dec 1, 2008 | 12:43 PM
  #112
RazorLab's Avatar
In simple terms...
A 3 port boost solenoid works without pills by design.
The factory solenoids(2) are 2 port and need the restriction on the positive pressure side to work correctly
The advantage to keeping the stock Ecu-boost control and just enhancing it (upgraded pill) is that you keep the pretty sophisticated factory boost control.
Some features of this are:
1. 18 point RPM based boost control
2. 9 point throttle based boost control (throttle %)
3. Two boost control tables for different driving styles
4. *gear based* boost control (The MR model uses this from the factory to limit boost in 1st gear from peak boost to around 5,000 rpm. The GSR does not use this feature. Both can be tuned to use it and use it in a performance aspect, example being more boost in 1st and 2nd and less in higher gears, or vice versa)
5. Full boost error correction (will increase or decrease boost to meet tuned target boost levels). This keeps the boost curve in check in different weather, road grades, load, etc
Old Dec 1, 2008 | 01:23 PM
  #113
mrfred's Avatar
I think that's an overstatement of the cost of suitable aftermarket solenoids for boost control. The GM BCS, which as proven to work very well on the Evo 8/9, is only about $35 from Rock Auto. Toss in another $10-$15 for replacement hose without any pills, and for ~$50, a much wider range of boost control can be had over the stock system or an MBC while still retaining all the safety features, tunability, and stability provided by the ECU-based boost control algorithm. The only downside to running a 3-port solenoid is that while an MBC is easy to tune (turn a knob until the boost range falls within acceptable upper/lower limits), the 3-port takes more work to tune. Its not for everyone, but for those who are willing to take the time to tune it, a solid step beyond an MBC.
Old Dec 1, 2008 | 01:39 PM
  #114
Silver Sponsor
I was refering to it being more expensive for mitsu to put it on there when they can achieve what they wanted with a 2 port.
Old Dec 1, 2008 | 02:09 PM
  #115
EVO-IX-MR's Avatar
Originally Posted by razorlab
In simple terms...
Awesome, thanks for that info. I have always like the idea of keeping boost control in the hands of the ECU for stealth reasons even though I knew even better reasons existed. Now I know those reasons .
Old Dec 1, 2008 | 07:59 PM
  #116
Wolfpak's Avatar
Can the AP clear the running count on how many times the factory ECU has been flashed?
Old Dec 1, 2008 | 08:00 PM
  #117
dcasandman's Avatar
^^^no
Old Dec 1, 2008 | 09:01 PM
  #118
DynoFlash's Avatar
Originally Posted by dcasandman
^^^no
I am unsure on that
Since the first thing the AP does when it is installed is to suck out the OEM data and store it on the AP, I am unsure what the ecu will look like after the data is transfered back onto the ecu when and if it is uninstalled.
I am nearly 100% certain the CVN will line up 100%
It remains to be tested to determine what trace - if any - is left of the process.
Al
Old Dec 1, 2008 | 09:07 PM
  #119
Withnail75's Avatar
Sorry if these are obvious to other people, but I have a few questions:
1. If the car gets a reflash at service time(which mine did apparently when I brought it in for its first service) can you download that new one to the AP?
2. I saw the maps on the website state factory air filter required. If I have a HKS drop-in how can I get a map that takes it into account?
3. Are there any threats to my warranty for using this device? Would I want to flash it back to stock before I take it in to the dealer for service? Keep in mind I am not asking for anyone's opinion on where to get my car serviced.
Cheers!
And to my fellow MR owners, there were maps for the 08 MR on the Cobb web site, so our cars are supported. I saw no one had answered that question specifically yet.
Old Dec 2, 2008 | 08:25 AM
  #120
Silver Sponsor
You can only download Cobb format maps to the AP. So if you are going in for service I would recommend uninstalling the AP so they can flash your car and then reinstall the AP.
You would need to get one built by cobb or a cobb certified Pro Tuner. There is a possibility that your panel filter will not cause problems with the map. But to be sure you would want to have it checked or run the stock piece.
With any modification you do to your vehicle if the dealer believes this part caused the part to fail they can deny you service on that item. The dealer cannot void your entire warranty for it just on the parts that it effects. I would uninstall it not to trick the dealer but just in case they need to flash the car you will not have them clearing out your cobb map.
