Cobb Tuning Access Port Is Now Available For The Evo X!
Old Dec 2, 2008 | 05:21 PM
  #136
Papi4baby's Avatar
Originally Posted by Dosagex
wow 30 min
Well it did say it was optional to do it. But i just turn the car off and will try tomorrow. So i guess you could skip saving the stock flash and save 30 min.
Old Dec 2, 2008 | 05:26 PM
  #137
Withnail75's Avatar
Originally Posted by JWA
That's technically true, but not answering his question correctly.
When you install the AccessPort map on the car it "marries" itself to that particular car and stores a copy of the current ECU code. When you uninstall it, it "divorces" itself from the car and puts it back to the code that it stored when you married it to the car. Thus, if you divorce it from the car, take the car to the dealer and they re-flash it, when you then re-install the AP map on the car it will marry itself to the car again, copying the new dealer flash which is currently in the ECU. If you then divorce it from the car at a later date the ECU will be returned to the way that it was the last time that it was married - in this case with the factory re-flash. That's what I understood Withnail75 to be asking.
I got the gist of what he was saying, and it looks like that would be the best of both worlds if I un-married(divorced?) before I got the dealer re-flash, then the AP would have that fresh flash store within when I re-attached . The ability to remove everything if I sell the car and probably recoup most of my cost on the AP makes it all seem an even better deal. Winter tires are more of a priority right this second as I have just given the Tire Rack a bunch of money, but the Cobb product is definitely on my holiday wish list.
  #138
smoothevo's Avatar
Do it NOW I can't wait to hear the results
Old Dec 2, 2008 | 05:56 PM
  #139
Papi4baby's Avatar
Patience my padeone patience.
Old Dec 2, 2008 | 06:58 PM
  #140
ZWingerRyRy's Avatar
Spent $695 and deciding to sleep on the results..
Thats like buying a PS3 right when it came out and deciding to go to bed when you got home instead
Old Dec 2, 2008 | 07:28 PM
  #141
evo_Eks's Avatar
will they offer maps each bolt on later?
Old Dec 2, 2008 | 08:19 PM
  #142
SilverEvoX's Avatar
When is the stage 2 flash going to be available is what I'm wondering
Old Dec 2, 2008 | 08:38 PM
  #143
smoothevo's Avatar
Most likely when their exhaust comes out if I had to guess. Like the staged packages they have for the STI.
Old Dec 2, 2008 | 11:04 PM
  #144
FujiwaraTofu's Avatar
It's Padawan.
Old Dec 2, 2008 | 11:37 PM
  #145
Web9's Avatar
Just got my Accessport today!
Unfortunately it's cold and snowing out so I don't think I'll be able to load the map until Friday or Saturday
Anyway, make sure to read the map notes for the Stage 1 map. (Stock filter only)
Old Dec 3, 2008 | 06:24 AM
  #146
pltek's Avatar
wicked good excuse, i think that you should wait till spring, more power and snow = not good
Old Dec 3, 2008 | 08:58 AM
  #147
Papi4baby's Avatar
Originally Posted by FujiwaraTofu
It's Padawan.
Silence you fool.... The force is stronger than my spelling...
I see im not the only one .
Yes i put the stock filter back on already.
I just flash the car, took about 15 minutes to back up the OE map, and about 5 to flash the cobb map, going out for a bit to pick some stuff up. I'll let you guys know how it is once i get back.
Old Dec 3, 2008 | 09:09 AM
  #148
RallySport Direct's Avatar
Silver Sponsor
They are just working out some boost control issues due to the factory solenoid not working very well at higher boost pressures. As soon as they have the fix for that the map will be available. So it should not be to long now.
  #149
scottatyamaha's Avatar
^ cant wait for the results! Nice packaging as well.
Old Dec 3, 2008 | 09:59 AM
  #150
Papi4baby's Avatar
The packaging is top notch. Kudos to COBB on that.
Well i can tell you for sure that the car gain HP, how much i dont know. The engines does seen to breath alot easier now, and yes the rev limit is been raised to 7.5 i didn't push any farther since i dont want to hit it.
I guess is not really what i was expecting but it is quicker. Maybe the car is just so smooth that is hard to tell. As of right now i will say the gains are so so, will have to find a stock evo and make a run see what happens, since i wont be hitting a dyno anytime soon.
I am not too down since the device does alot more, and i just got it. So im sure i have more to learn about it and more to gain from it.
Quick question, i was reading the manual and from the wording it looks like the software to street tune is not free??? It says i can upgrade to it? So if i get my AFR meter and decide to adjust the map i would have to buy this software???
