JDM MIVEC Map results?
Old Dec 27, 2008 | 08:10 AM
Guru's Avatar
I added some aggressiveness on the intake cam already but these look even more so. Think I'll put this in although I'll have to mess with them on the dyno to get the best results for the Red.
Old Feb 3, 2009 | 03:06 AM
vboy425's Avatar
Originally Posted by Rguy
Top is JDM, Bottom is USDM.
INTAKE:
EXHAUST:
on my GSr usdm rom. it's weird, your usdm map GSR mivec 1 map is identical to my mivec map #2 in the rom ? so which one do i change ?
Old Feb 3, 2009 | 03:11 AM
gunzo's Avatar
Put both the same .. Map #1 is warmup till 77 degrees C .. Map #2 is normal mivec post warmup ..
Old Feb 3, 2009 | 03:21 AM
vboy425's Avatar
ah. i see what you say now. thanks. I also email you about a a jdm or edm mivec rom. thanks
...Charlie@MFq Motorsports
Old Jul 16, 2015 | 09:56 PM
wamang's Avatar
EcuFlash defenition file
Hi:
I using evo 9 wagon 6 speed i try the definitation but it cannot edit the mivec map, what file should i use at rommetadata
can any one pls help
ecu id 88770005
Girlie
Jun 6, 2019 11:11 PM
EvoDom
Feb 11, 2019 11:06 AM
fireroasted
Oct 6, 2015 04:41 PM
Huy's Evo
Oct 1, 2012 07:04 PM
eficker
Oct 22, 2006 10:34 AM
