ECU Flash on P1245 code
Old Feb 2, 2009 | 10:38 PM
gunzo's Avatar
52350016 is a JDM RS ROM ..
So you have no boost cut or boost limit ..
better make sure your definition is correct before you change ..
Old Feb 3, 2009 | 06:02 AM
burnings's Avatar
Just noticed that I am on 52360016
Old Feb 3, 2009 | 12:21 PM
burnings's Avatar
Originally Posted by GST Motorsports
If you have a EBC installed and are not using the stock ecu to control boost at all, just raise the Boost Offset from 80 (stock) to something large like 300 or so. That way you don't even have to touch target engine load maps.
I have raise the offset to 300 and still hits the code. Wonder if I should max it out and try again...
Old Feb 3, 2009 | 06:01 PM
gunzo's Avatar
BDEL is only part of the equation for P1235
This is one of the reasons why I mentioned its not good to use either EBC or MBC on this car .. most of those using the stock boost solenoids are running the same boost as those on EBC ..
How much boost are you running ??
We'll walk thru this step by step..
Old Feb 3, 2009 | 07:24 PM
GST Motorsports's Avatar
Then it's not boost target related.
Look to the airflow target tables next.
When does it trip the code? low rpm WOT?, low rpm part throttle?, etc etc?
Old Feb 4, 2009 | 03:51 AM
burnings's Avatar
I am running 1.3bar and 1.7 bar respectively. Usually the checklight comes on at ard 3000 - 5000 rpm at 80% throttle.
When cruising 5th gear 3000rpm and increasing the throttle to 80% it will throw a limp mode at abt 5000 - 6000rpm..
Old Feb 4, 2009 | 03:54 AM
burnings's Avatar
I noticed Airflow check has 4 tables of which table #4 is different from the rest. I tried increasing the airflow tables 40% and it immediately when into Limp Mode. So i guess the more isnt better..
I am looking at more stable performance when I increase the airflow check to 30% but it will still throw the code but at a later rpm. Can the Airflow #4 be edited?
Old Feb 10, 2009 | 09:04 PM
PR_Mivec's Avatar
ok im running the same problem... did the offset thing... and still have the code.....
it happened today at 4th gear @ +4000rpm
im quite close to just take out the ebc and fiddle w/ tables....
Old Feb 11, 2009 | 12:22 PM
burnings's Avatar
I actually adjusted the Passive WG duty cycle and it seems to help in the problem. I no longer gets the error but i havent tried part throttle acceleration yet. Will see how it goes..
Old Feb 11, 2009 | 08:22 PM
awddyno's Avatar
I got my new cable so I will be on this. ( I broke my cable and had to send it for repair last week)
Old Feb 13, 2009 | 06:50 AM
burnings's Avatar
Code 0122,1233
I got a new code P0122 and P1233. This happens only at low speed and low rpm. The car throws a check light and acceleration is very very slow. Itz definitely not running on low octane map and I am not sure wat causes it.
Old Feb 13, 2009 | 09:41 AM
DB Performance's Avatar
DTC P1233: Throttle Position Sensor (main) Plausibility
TECHNICAL DESCRIPTION
Compare the actual measurement of volumetric efficiency by a mass airflow sensor signal with volumetric efficiency estimated from a throttle position sensor (main) signal.
DTC P0122: Throttle Position Sensor (main) Circuit Low Input
Old Feb 13, 2009 | 01:53 PM
burnings's Avatar
Hmmmmm..... Thanks.
Old Feb 13, 2009 | 01:55 PM
boosted9's Avatar
cool
Old Feb 13, 2009 | 02:30 PM
PR_Mivec's Avatar
burnings did you touch the airflow tables?
i wonder
on stock form the 1 and 3 tables are the same #2 is different.. any guess why?
