going lean after 2 weeks of perfect AFR
Old Mar 12, 2009 | 03:15 AM
hameedosh's Avatar
here's what happened in short:
my car was doing very good, i went to the car wash to meet a friend (didnt wash my car) i opened my agency power BOV cover thing to let him hear the sound (was closed before) after that my AFR went crazy, reading 17+ when idleing and 12.5~14.5 when at full throttle,
so i started snooping around but couldnt find any thing.
but just to be sure, is this harness supposed to be unplugged (the gray one)??
please help!!!
Old Mar 12, 2009 | 03:44 AM
Td66's Avatar
Mines unplugged!
Old Mar 12, 2009 | 04:05 AM
hameedosh's Avatar
^^ thats good to know
Old Mar 12, 2009 | 04:08 AM
hksevoix's Avatar
so your question is afrs or the plug? lol
Old Mar 12, 2009 | 05:30 AM
hameedosh's Avatar
no i just suspected the plug, but now that its not it, WTH is happening, why is it so lean ??
Old Mar 12, 2009 | 05:32 AM
AF-Evo8's Avatar
so you Set your BOV to VTA and then you had these AFR's? If this is the case try unpluging you negative battery cable for 10 mins or so to reset you ECU and see what happens.
Old Mar 12, 2009 | 06:37 AM
hameedosh's Avatar
will do
Old Mar 12, 2009 | 06:39 AM
goofygrin's Avatar
Are you throwing a code now? Mine threw a "too lean" code when my o2 housing cracked.
My AFRs were 18-19 at idle and basically normal on throttle though.
Old Mar 12, 2009 | 08:24 AM
Mad_SB's Avatar
Check your Fuel Pressure regulator line, it probably popped off, I've seen that happen on two X's so far (one was mine).
Either that or your BOV spring is too soft and it is pulling in un metered air since you switched it to vta. Unless you did something silly like had it set to recirc and just pulled the end out of the intake pipe, in which case you are sucking in a ton of un metered air.
Old Mar 12, 2009 | 08:42 AM
hameedosh's Avatar
exactly whats happening to me right now
i will see what i can do
Old Mar 12, 2009 | 10:08 AM
Noize's Avatar
EvoM Administrator
Thumbs down
I zip tied mine last night.
Old Mar 12, 2009 | 12:47 PM
hameedosh's Avatar
thanx fellas all fixed
turned out to be a poped out hose on the throttle body...
zip tied the hell outta of it
Old Mar 12, 2009 | 09:20 PM
TTP Engineering's Avatar
At 30+psi, its definately a requirement.
Old Mar 13, 2009 | 07:13 AM
Noize's Avatar
EvoM Administrator
I blew that line off my VIII with a TME 16G at 25psi on race gas back in 2005. Sucked, cracked a piston. When I went to a 30R and 31psi, everything was zip tied.
Live and learn.
slowboi_x
Feb 21, 2016 01:22 AM
slowboi_x
Feb 17, 2011 10:46 PM
hameedosh
Jul 22, 2009 03:41 AM
Hong Kong Evo
For Sale - Cars For Sale
May 26, 2007 11:15 AM
