TephraMODs for the X
yeah ill do an MR ROM
can someone send me the absolute latest dealer flash for the 08 USDM MR?
since the 52680022 GSR ROM is like 5 seconds old, you may need to go to the dealer ...
Damn! If it wasn't 50 miles away and I wasn't set up for E85.. I'd do this in a heatbeat.. Oh well =(
thanks guys..
I think 52690021 is the most recent MR ROM?
can someone with a stock MR goto the dealer and get the most recent flash? I suspect there might be a newer one...
KnockCEL
* load threshold
* 2 levels of knocksum threshold, will dictate a slow OR fast flashing CEL
* added TPS cut feature when hitting the high knocksum threshold
Map Switching
* different enable/disable methods (TPS or CruiseControl or 5V ADC or Resistor based ADC)
* all major maps being switched
* load threshold
Map Switching
ok RC3 of the 2008 USDM GSR ROM sent to testers... RC3 includes a safety feature for the KnockTPSCUT - which should make the system completely safe
I think that will be the final build, just waiting for the testers to OK it..
Once I get the most recent 2008 MR ROM (ie greater than 52690021) I will do that ROM up ASAP... Then I will work on the 2010's
