EvoX solenoids question
Old Mar 23, 2009 | 04:36 AM
AIK's Avatar
AIK
We have two boost solenoids one over another in EvoX.
Which of them is reactive and wich is passive?
Thanks.
Old Mar 23, 2009 | 07:12 AM
Mad_SB's Avatar
Thanks.
Why do you need to know, as in what are you trying to accomplish? EcuFlash has them labeled as active (primary) and passive (secondary). EcuTek just calls them Primary and Secondary. Shop manual should show you which is which.
Are you wanting to put a bleed on the secondary or something?
Old Mar 23, 2009 | 07:21 AM
burnings's Avatar
The one closest to you is the reactive....
Old Mar 23, 2009 | 07:55 AM
AIK's Avatar
AIK
I'am using 3-port GM and EcuFlashed WGDC tables on my Evo8 now.
I want change reactive solenoid to 3-port GM + resistor and desaible passive solenoid on EvoX. But i can not understand which is which ).
Old Mar 23, 2009 | 10:27 AM
pltek's Avatar
ecuflash calls it reactive and not reactive on the X maps
Old Mar 23, 2009 | 04:01 PM
AIK's Avatar
AIK
That which above?
Old Mar 23, 2009 | 04:10 PM
AIK's Avatar
AIK
They named "solenoid 1" and "solenoid 2" at the manual. And they have the same part.number in the shop-manual.
Old Mar 24, 2009 | 03:19 AM
Mad_SB's Avatar
Well crap thats no good then. You could always just unplug one (from the wiring harness) and see what code it throws, the code might tell you whichis which.
Then again if the manual calls them 1 and 2, I would assume 1 is reactive aka primary and 2 is passive aka secondary.
Old Mar 24, 2009 | 06:02 AM
burnings's Avatar
That which above?
Old Mar 24, 2009 | 02:24 PM
AIK's Avatar
AIK
burnings
Thanks you.
ddevox
Apr 28, 2017 03:41 PM
Olegator
Oct 16, 2016 10:37 PM
Freddy302
Oct 14, 2016 05:04 PM
evo267
Jul 22, 2009 07:51 PM
Sevi_EvoX
Sep 18, 2008 07:06 PM
