Stationary Rev Limiter
Old Apr 1, 2009 | 12:59 PM
rfielder's Avatar
Has anyone had any issues with changing the Stationary Rev Limiter (2 Stage) in Open ECU? The factory setting is 5500 for the "on" value and 5300 for the "off" value. I changed the values and the rev limiter stays at the factory values.
Old Apr 1, 2009 | 01:13 PM
DG Motors's Avatar
I have ours set to 6200...No problems.
Can you specify exactly what you are trying to do?
Old Apr 1, 2009 | 02:24 PM
rfielder's Avatar
I was trying to lower the launch RPM. 5300 may be the minimum the ECU can support. Maybe?
Old Apr 1, 2009 | 03:39 PM
EvoX_SA's Avatar
Mine is set to 4500 rpm with the stage 3 map from Perrin. (accessport) So you should be able to set it to whatever you want. 4.5k is too low. I wish it was 5.5k again. I may have them send me another map.
Old Apr 1, 2009 | 04:18 PM
dek0026's Avatar
just open the map in accesstuner race and change it yourself. super easy. unless it is locked which perrin does do.
OP: you can set it where ever you want. i took my cobb valet map and set the stationary rev limiter to 2000 and confirmed it.
Old Apr 2, 2009 | 12:13 AM
KOTT's Avatar
have same problem, trying change stat rev limiter on EDM evo, change both values to 6.5, but stat rev limiter stay on old values
Old Apr 2, 2009 | 01:14 PM
EvoX_SA's Avatar
unfortunatley the map is locked
Old May 18, 2009 | 09:10 AM
mrfred's Avatar
In looking at the code in the region of where the "stat rev limit" tables are called in the USDM GSR ROM, it looks like the wrong tables are called. Did you guys use ECUFlash to adjust the stat rev limit? If yes, was it a USDM Evo 10 that you successfully adjusted?
GeoMitsu
Nov 14, 2013 04:22 AM
BeyondLimitsEvo
Cobb AccessPORT
Jul 20, 2012 08:07 AM
Mauricio Evo IV
Dec 29, 2010 06:42 AM
EVO8emUp
May 31, 2008 01:37 PM
Evo_Pma
Jul 6, 2007 09:32 AM
