conical cone filter and stock blow off valve...wow
i have an old cone filter i used in my civic and it's not dirty. i put it in and wow. first the blow valve is louder, i mean it's the first time i hear it. i told my self ohhh i have a blow off valve?? so this is the stock blow off valve.this is my first turbo car so im clueless. i put an intake on my civic and pathfinder but with evo it's so obvious there is a huge difference from the the response and the way it sound.
now with the blow off valve im just scared with all the shhh i heard, im not sure if they are just normal. on normal mode while shifting from 4th to 5th gear in between it will make a flutter sound not the usual blow off valve sound but not on sport mode. is this normal?
do you think the k and n drop in will sound the same as the cone filter?
ok here is the way it sounds.... 100% the same with stock BOvalve..... is it the same your drop in. because i really like to look like stock... but sound really diff and notice that chhhh on @ 33 sec that's what im asking for, they sat it's normal.
http://www.youtube.com/watch?v=EBvPQ...layer_embedded
OP: What you described are all sounds you should expect from a turbo car with a BOV. However, if you plan on keeping that cone filter on there you'll need to put some kind of shield in place for when you're radiator fans are on. Otherwise your MAF gets grumpy.
+1 I have the WORKS drop-in as well and definitely makes the BOV louder.
I was wondering about the fluttering sound too. Only happens on my wife's mr...not on my gsr. I was assuming it had something to do with how the sst puts load on the engine. My wife hated the sound so we put the stock filter back on to mask the flutter.
i had recirc.bov,and i tried to loosen the spring and i heard louder soudn from the bov but also i hears kinda same sound when i was hard acclerating from 1 and 2 gear.today i put there the factory one bov and i can hear it but also i can hear that sound from 1 and 2 gear while accelerating but not that loud like the other one but i can hear the sound by accelerating,,like if there is a leak or something.
is that good??
is that good??
These cars are ridiculously rich stock, that's why just an intake frees so much HP... it's leaning out the A/F ratio.
ak47m203: My AMS intake sound identical to the one in that video. I could replicate all of those sounds with my GSR, even the fluttery ones. Supposedly a drop-in brings the volume of the BPV down, and eliminates the air-sucking whoooshy noise when under medium to full throttle. So, no, it wouldn't sound the same.
kaoscage
152
Jul 13, 2013 10:52 AM
Neteru
13
Oct 2, 2009 06:41 PM
