Sigh. P1235 4 days in a row now.
Well, at lunch I tried out the new map. No P1235, but I got a u0167. I did have the AP hooked up to the ECU to log when this happened, but it was during my "passing" test (in 3rd gear) and the boost spiked to 28.4 as logged by the ECU.
Its the boost spike at partial throttle in high gears, any reflash will do this without editing the proper tables.
I could tell you how to fix it in like two seconds in EcuTeK or Ecuflash, but I have no idea what the Cobb interface looks like, or what level of access the end user gets to the maps.
The Cobb interface is counterintuitive in the race tuner program. Rather than have the load on the x-axis like ECUflash and ECUtek, Cobb has it on the y-axis. The RPM, on the other hand, is on the x-axis. I do not know why they do it like this. Every tuning softawre that I have used/seen (xede, Ecuflash, Ecutech, Tunerpro) has the load on the x-axis and the rpm on the y-axis. Cobb uses the opposite. I have no idea why they do this.
- Bryan
They want to make it hard for people to copy their DLed maps into other other programs.
I logged one of their DLed maps on an Evo 10 using their software and the car ran rich (10.7:1) and the logged timing did not match the timing numbers in the 3D timing table. Strangely, there was little to no knock retard
I am still looking for an explanation.
I find it hillarious that Cobb thinks that others will copy this map and put it on other cars
strang3majik
Aug 6, 2015 08:46 AM
GravityKnight
Feb 26, 2015 08:53 AM
zTargeTz
13
Aug 1, 2011 06:33 AM
otbEVO
Jul 6, 2009 08:11 PM
