Evo X Logging
Old Jun 18, 2009 | 01:55 PM
  #391
xbox4414's Avatar
So question, I may be a few weeks behind, but did the cap in PCMScan on boost get resolved then?
Old Jun 18, 2009 | 02:06 PM
  #392
nj1266's Avatar
You have to log Mode23 either with the Tephra logger or Evoscan to get the uncapped boost. I do not know if flashing the rom with Mode23 code would uncap the boost limit using PCMScan. I will try it on Saturday and report back.
Old Jun 18, 2009 | 04:23 PM
  #393
tephra's Avatar
no it doesn't
the OBD spec calls for a max of 255 kPa - hence the cap.
With Mode23, we are logging the raw MAP signal - hence we don't get capped...
Old Jun 18, 2009 | 04:53 PM
  #394
xbox4414's Avatar
What does it do that? Anyway to change that? I like using your data logger, but it doesn't create a nice map graph. Haven't figured how how to do that in Excel. And I don't have EvoScan yet...
Old Jun 18, 2009 | 05:34 PM
  #395
tephra's Avatar
change what? the cap in pcmscan?
i could - but im not going to...
get evoscan
Old Jun 18, 2009 | 05:38 PM
  #396
Hiboost's Avatar
What is the CAN ID for boost logging in EvoScan Beta anyways? Or are we only able to use Mode23 at this time? It seems like the Baro caps at 125 kPa (~3.6 psi above Atmospheric) but is still a good way to verify the readings. Even if I can get to 255 kPa that is 22.5 psi and I can time spoolup more accurately.
Thanks!
Old Jun 18, 2009 | 05:42 PM
  #397
tephra's Avatar
Code:
<DataListItem DataLog="Y" Color="" Display="MAP" LogReference="MAP" RequestID="CAN6-0" Eval="x" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
Old Jun 18, 2009 | 06:03 PM
  #398
SiC's Avatar
SiC
Originally Posted by criptballer
Hey mrfred, how do i convert the IPW into IDC? that way i'm going to be able to see at what point they max out right?
Input this into your Evoscan data.xml
<DataListItem DataLog="N" Color="" Display="IDC" LogReference="IDC" RequestID="2380874f" Eval="[Mode23IPW]*31.25*x/1200" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="100" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
Old Jun 18, 2009 | 08:05 PM
  #399
NMX's Avatar
NMX
Thanks!
I could be wrong but I want to say that I tested this out with CAN 6-0 and it caps at 255 very easily at part throttle. I think the problem is that it looked like it was reporting absolute pressure, so 22.5-14.5=8 psi. Try it out, but I couldn't really get usable boost logging with CAN. The mode23 boost logging works great though!
Old Jun 18, 2009 | 08:16 PM
  #400
mrfred's Avatar
My latest Data.xml for USDM Evo 10 GSR 52680015-20 is attached. Changes include:
- APP and TPS now should be range from ~0 to ~100%.
- Added IDC calculation.
- Added back the wide band logging entry.
- A few other minor changes.
Old Jun 18, 2009 | 08:21 PM
  #401
mrfred's Avatar
Originally Posted by SiC
mrfred, do you have the MUT addresses for these instead of the raw addresses. I'm having a hard time finding them for the JDM 52360018.
Yeah, some of these are not in the MUT table, but something close might be in there that you can use as a reference point to get the correct address. Which items are you looking to duplicate in your Data.xml?
Thanks!
Forget the CAN method. All problems are solved with Mode23.
Old Jun 18, 2009 | 08:26 PM
  #402
Hiboost's Avatar
Yeah I have Baro the same as 6-0 so it will cap out at 125 kPa, Mode23 it is!
Old Jun 18, 2009 | 09:49 PM
  #403
SiC's Avatar
SiC
Looking for some addresses for JDM 52360018.
- APP & TPS
- The 2 other loads (Mivec & timing)
- Manifold air temp (Charged air temp)
I think I have the AFR map which is 238088f0
Also, these should be the mivec on the JDM
Code:
        <DataListItem DataLog="N" Color="" Display="InVVT" LogReference="InVVT" RequestID="23809450" Eval="(x-3552)/48.64+10" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="ExVVT" LogReference="ExVVT" RequestID="23809452" Eval="(x-4096)*-0.01953" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
Old Jun 18, 2009 | 10:03 PM
  #404
xbox4414's Avatar
get evoscan
Why?!? No fair! LOL. I paid for PCMScan I don't wanna get EvoScan too. Haha.
Old Jun 18, 2009 | 10:19 PM
  #405
SiC's Avatar
SiC
I think alot of us used/paid for PCMScan when we had no other option, it's time to let go......
