EVO X HKS FCON PNP Harness: FINALLY
Old Jul 13, 2009 | 11:06 PM
projekX's Avatar
Exclamation EVO X HKS FCON PNP Harness: FINALLY
HKS JAPAN HAS RELEASED THE PNP HARNESS KIT FOR THE EVOX!!!!
The part # is (42002-AM002) and it includes:
-Mounting Case
-OBDII Communication Cable [No. 42999-AK009]
-Injection Generic Adapter (42999-AK004)
-Ignition Generic Adapter 2 (42999-AK008)
Unfortunately it is only available in JAPAN at this time. So if ya have a contact, lucky us! The rest of you will just have to wait
Happy Tuning!!!
Old Jul 13, 2009 | 11:45 PM
tephra's Avatar
meh...
stock ECU FTW!
Old Jul 14, 2009 | 05:56 AM
EDBOYLI's Avatar
..so is this a actual EMS system or a piggyback????
Old Jul 14, 2009 | 08:19 AM
projekX's Avatar
The FCON VPRO is a stand-alone and the FCON iS is a piggy back. The VPRO retails for $1450.00 and the iS for $750.00.
Here is the info on the HKS FCON VPRO:
HKS F-CON V Pro version 3.3 released for the North American Market.
HKS USA, Inc. releases the newest version of its engine management system, the F-CON V Pro version 3.3. The new F-CON V Pro hardware and Power Writer software have been upgraded to offer improved functionality and features over the previous generations.
The HKS F-CON V Pro is a full featured standalone engine management system that connects easily as a "piggy-back" fuel and timing controller. As modifications to a vehicle are made, the need for fuel and timing adjustments becomes critical for performance and safety. With up to 4 selectable trim maps for different fuel octane ratings, the F-CON V Pro with its 32x32 resolution for both fuel and timing maps is the optimal solution.
The F-CON V Pro can control up to eight injectors with D Jetro or L Jetro setups. Injectors can be set to fire as batch, sequential or staged. The F-CON V Pro can also be utilized in “drive by wire” vehicles. Programming is done via the HKS Power Writer software; which only Certified HKS Pro Dealers have access to.
The HKS Power Writer software for the F-CON V Pro has some very unique abilities to simplify setup and tuning. The F-CON V Pro utilizes A/F Feedback control; where a target A/F value can be input and the F-CON V Pro will adjust fuel automatically. Full data logging capabilities are also built into the F-CON V Pro Power Writer software allowing all major vehicle conditions; speed, rpm, water temperature, intake temperature, timing, boost, injector duty cycle, etc. to be logged onto the HKS Pro Dealer’s computer.
The newest functions of the F-CON V Pro 3.3 include:
• Newer vehicle compatibility including Mitsubishi’s Lancer Evolution X
• Air flow input voltage monitoring
• Direct inputs for: Fuel pressure, Oil pressure and Oil temperature
• Compatibility with the HKS A/F Knock Amp 2 (AFK)
• Deceleration fuel cut by vehicle speed, improving low speed drivability
• Flat shift (wide open throttle) rpm control
• Pit lane speed limiter
• Compatibility with HKS Valcon
• Improved Idle Control Valve control
• Error code reporting and memory function
• Oil Pressure, oil temp warning light option output
• RPM, ignition cut, and data logging warning/indicator light output
The HKS F-CON V Pro and tuning is only available exclusively through select Authorized Pro Dealers.
*The F-CON V Pro version 3.3 is currently NOT compatible with the HKS F-CON Navigator and Navigator Pro.
Old Jul 14, 2009 | 10:27 AM
abu's Avatar
abu
So are you planning on running the FCon Vpro? I am thinking of running th FCon either IS or VPro, but there just hasn't been too many cars running them. Just curious, where you you saw the news that the harness is out. I recently spoke with a HKS rep and they said it was not available.
Old Jul 14, 2009 | 03:49 PM
projekX's Avatar
If you read my post, i stated that it was available in JAPAN ONLY. I have a contact at HKS USA, who gave me the part number. Then, i gave then part number to my contact in Japan and he said it is in stock in JAPAN. Mine is on its way...
Old Jul 17, 2009 | 08:41 PM
abu's Avatar
abu
So are you planning to run the VPro or the IS?
Old Jul 19, 2009 | 02:33 AM
projekX's Avatar
I will be running the FCON VPRO, along with the A/F Knock Amp. Viewing engine diagnostics via CAMP2...
Old Aug 1, 2009 | 11:04 PM
Jun3sgte's Avatar
amazing system
Old Aug 2, 2009 | 10:51 AM
boostin20's Avatar
Sweet, I bet Ivey loves this release.
Old Aug 2, 2009 | 12:29 PM
derekste's Avatar
Originally Posted by tephra
meh...
stock ECU FTW!
Old Aug 4, 2009 | 01:47 PM
projekX's Avatar
Here she is, directly from Japan!!!
Attached Thumbnails EVO X HKS FCON PNP Harness: FINALLY-dsc_0001_edited-1.jpg   EVO X HKS FCON PNP Harness: FINALLY-dsc_0002_edited-1.jpg   EVO X HKS FCON PNP Harness: FINALLY-dsc_0003_edited-1.jpg   EVO X HKS FCON PNP Harness: FINALLY-dsc_0004_edited-1.jpg   EVO X HKS FCON PNP Harness: FINALLY-dsc_0008_edited-1.jpg
tmaddox
For Sale - Wheels / Tires
Oct 21, 2016 05:04 PM
bluepeartype-s
Dec 13, 2015 12:20 PM
jmiranda181
Northeast Region
Jun 30, 2011 03:36 PM
02OZR
Lancer Engine Tech
10
Sep 12, 2006 04:20 PM
PHILLY EVO
For Sale - Cars For Sale
10
Apr 30, 2006 08:02 PM
