Good widebands?
Old Sep 10, 2009 | 10:08 PM
  #46
tipoytm's Avatar
Originally Posted by nj1266
That is a great price. If I did not have two of them, I would have jumped on it.
I would have... but my access to funds is currently restricted by the family treasurer
Old Sep 11, 2009 | 07:47 AM
  #47
ChrisCarey's Avatar
Originally Posted by LaXGSR
Got mine from Modern Automotive Performance (maperformance.com). PM them for a quote. They had great, fast service!
Thank you for the kind words We generally have the Innovate LC-1 standalone kit #3769 as well as all variations of their gauge kits in stock and ready to ship. As mentioned above simply PM us for the best pricing on the market!
Old Sep 11, 2009 | 10:50 AM
  #48
L-SCHLEGS's Avatar
i like the aem uego, i had a lc-1 but i didnt like having to re-calibrate it, i mean why, when the aem does everything for you. get in and turn the car on and its always good to go
Old Sep 11, 2009 | 11:14 AM
  #49
Brsox10288's Avatar
Do any of these products come in 60mm gauges?
Originally Posted by ChrisCarey
These are pretty popular, again PM for best pricing
Old Sep 11, 2009 | 12:15 PM
  #50
Clipse3GT's Avatar
FTW!
I will coming out with a how to: for connecting the UEGO to EVOSCAN
Old Sep 11, 2009 | 07:22 PM
  #51
NJ_EveOhVIII's Avatar
Originally Posted by Clipse3GT
FTW!
keep us posted when its finally up
Old Sep 11, 2009 | 09:07 PM
  #52
gunhaha's Avatar
Originally Posted by Jim in Tucson
I've been asking the same question. Does any wideband come with a direct USB laptop plug-in cable? I couldn't find any.
I'm planning on getting a wideband myself next month. Zeitronix is at the top my list. I mainly want it for data logging, so my question is this: is a gauge/display worth the additional money?
YES. It allows you to do a quick check without your laptop if your AFR is still spot on by doing a short 3rd gear pull.
Old Sep 14, 2009 | 11:13 PM
  #53
funks's Avatar
funks,
One reads AFR and one reads boost. They work great. You can connect from the XD-16 to your laptop and keep the XD-16 reading AFR/boost while logging. If the DB does not connect via serial output, the XD-16 100% does.
Reading the manuals, I believe I'm wrong about the LC-1 + DB Gauge combo not being able to log via laptop.
The DB guage BLUE wire uses the analog out signal (0-5v) from either the LC1 or the LM1. And I believe the LC1's connection to the PC is via SERIAL OUT so it should be fine.
For the DB Guage + LC-1
1) Connect the DB gauge blue wire, to brown analog output wire on LC-1
For the DB Guage + LM-1
1) Connect the DB guage blue wire, to white analog output wire on LM1
I guess one can also use the XD-16 but that's the expensive route if you only want a gauge + being able to laptop log.
In another note, the PLX SM-AFR device also looks nice 166$), or in a combo with their Single Gauge (238$.
Too bad EvoScan doesn't support it (anybody asked Hamish?). It hooks up to the PC via USB (has a Driver) and uses the device pictured below (1/8" plug connects between that dongle, and the Serial TX on the wideband controller) which costs 66$ - kind pricey. It uses FTDI drivers (so support for all operating systems is a given). I'm not sure if it uses VCP (Virtual Com Port), or D2XX mode (access via DLL, similar to how the OpenPort stuff is accessed). If it's VCP (most likely) then it's just a matter of parsing out the datastream packet being sent into the com port (similar to the LC1, LM1, AEM, ZT2).
Once i'm done with the Diff Viewer, I'll bug tephra and ask for his mitsulogger code. I'll then add dead simple logging support (bare minimum attributes) on the Diff Viewer + more widebands (ZT2, PLX, AEM, LM1, LC1 in that order).
Old Sep 15, 2009 | 12:04 AM
  #54
Octane Blue's Avatar
Originally Posted by l-schlegs
i like the aem uego, i had a lc-1 but i didnt like having to re-calibrate it, i mean why, when the aem does everything for you. Get in and turn the car on and its always good to go
+1
Old Sep 15, 2009 | 02:13 PM
  #55
funks's Avatar
funks,
I use an LM-1 in my Evo 9 with two xd-16s. One reads AFR and one reads boost. They work great. You can connect from the XD-16 to your laptop and keep the XD-16 reading AFR/boost while logging. If the DB does not connect via serial output, the XD-16 100% does.
Naji, SDEVO wants to buy my LM1 kit. Was wondering how you were getting boost via your XD-16?
Do you have the following setup?
LMA-3 (AUXBOX w/ 3 bar pressure nipple hooked up to intake manifold) connected to LM-1. LM1 -> 1st XD-16, then 1st XD-16 connected to 2nd XD-16, Finally 2nd XD-16 connected to computer?
Can he go with the slightly cheaper setup below?
LMA-3 (AUXBOX w/ 3 bar pressure nipple hooked up to intake maniflold) connected to LM1. LM1 -> XD16, XD16 -> Computer. The XD-16 will be setup to display Boost.
For the AFR gauge, he can then just use the cheaper DB gauge (hook the DB BLUE wire, to the LM-1 analog 0-5v WHITE wire).
Does this make sense?
Old Sep 15, 2009 | 02:41 PM
  #56
rfielder's Avatar
The Zeitronix works great with Evoscan. That is the only one I use when tuning. It is very reliable and requires no calibration.
Old Sep 15, 2009 | 02:47 PM
  #57
Spoolin' By U's Avatar
I like that PLX Devices version and or the new LCD Dynojet commander model.
As long as it has the 5 wire Bosch sensor or better though.
Old Sep 15, 2009 | 03:50 PM
  #58
funks's Avatar
^bump
Old Sep 17, 2009 | 04:53 PM
  #59
funks's Avatar
Originally Posted by funks
I bought one of these and it is indeed showing up as a Virtual Comm Port under windows using FTDI drivers. I'm going to read in the data from the serial port to see how the data is laid out. I'll then send the info to Hamish and hopefully - he'll add it to Evoscan.
Old Sep 17, 2009 | 05:17 PM
  #60
SWOLN's Avatar
Do a split, give a yell, shake your **** for ole Ridell. Yaaay !
