Good widebands?
Old Sep 27, 2009 | 01:29 PM
  #76
ilikeppie's Avatar
i vote aem, i am about to order mine i have not heard anything bad about it
Old Sep 27, 2009 | 03:55 PM
  #77
funks's Avatar
Originally Posted by mrubino83
^^^ Just ordered the same piece for my prosport oil pressure gauge.
You gonna be tuning your car w/ that prosport wideband? Are you gonna be hooking up the voltage output to the rear O2's ADC? Otherwise, it won't work with EvoSCAN.
Old Sep 27, 2009 | 05:06 PM
  #78
hotstix's Avatar
Im not gonna be doing any self tuning. This is just to moniter AFRs and make sure they stay where they should be.
Old Oct 3, 2009 | 06:03 PM
  #79
funks's Avatar
In regards to PLX users, I wrote an EVOXLogger (based off Tephra's Command Line Mode23 logger - thanks Tephra!) that works with the PLX and gives us a tuning solution until EvoScan incorporates PLX iMFD support.
Originally Posted by Funks
The MODE 23 EVOXLogger w/ Wideband based off Tephra's is alive. I'd like to thank Tephra for sharing the power of his source :]
It's not a straight C program anymore (now C++/CLI ), so it requires the .NET framework version 3.5 SP1
Wideband Currently Supported
"PLX"
"LM1" <-- needs testing..
"LC1" <-- needs testing..
"ZT2" <-- needs testing..
"AEM" <-- needs testing..
Monitors get configured as follows via file "monitors.config"
Code:
# Name:Source:HexAddress:ReturnBytes:RPNFormula:Priority
# 1) Make sure there are NO SPACES (including @ end)
# 2) Make sure your formula is correct - "x" is the value returned from the car.
TPS:OP2:0x8086F9:1:x,32,-,129,*,255,/:1
2ByteRPM:OP2:0x808746:2:x,3.90625,*:1
LoadFuel:OP2:0x80876E:2:x,10,*,32,/:1
LoadMivec:OP2:0x808774:2:x,10,*,32,/:1
TimingAdv:OP2:0x808A07:1:x,20,-:1
KnockSum:OP2:0x808A4B:1:x:1
PSIG:OP2:0x80871A:2:x,4,/,0.19347,*,14.5,-:1
WideBandAF:WB:0x000000:0:x:1
The wideband stuff like this via file "wb.config"
Code:
# Type:COMPORT:TestMode
PLX:COM4:false
When you run the "evoxlogger.exe" it automatically creates a log file in the relative "logs" folder..
The autogenerated filename is generated with the following format - example: "EVOXLoggerDataLog-2009_10_01-22_58.csv"
If you run it as such "evoxlogger.exe C:\temp\mylog.csv" then it writes to the file file path passed in..
Old Nov 4, 2009 | 06:29 AM
  #80
shh!! sleeping's Avatar
This question was posted earlier in the thread but no one seamed to answer... but any feedback on the NGK AFX Wideband ? Does it work with EvoScan? Any + or - from any one who has installed or tuned with it?
I've been looking for a wideband with a display, but i do not want to run a gauge cuz... well... im OCD and Defi doesnt have a wideband gauge and all my gauges have to be the same... the AFX had a red digital readout and its pretty small at that, so i was going to install it where the clock is on the dash just above my Defi 3 gauge setup where the stock radio was... i know it look sick... but its got to be functional and worth my time...
Feedback on the AFX???? anyone???
Old Nov 11, 2009 | 03:34 PM
  #81
JimGVT's Avatar
For those of you using the Innovate LC-1, did you replace the factory O2 sensor and then use the narrowband output from the LC-1 to simulate the narrowband to the ECU? If so, did you run into any issues? Thanks.
Old Nov 11, 2009 | 03:46 PM
  #82
EVO_MERLE's Avatar
be careful that sandwich plate puts your oil filter dangerously low to the ground and can get hit or punctured. You can tap for oil pressure on the side of your oil sending unit.
As far as wide bands go i wanted the pro sport as well but found a LC-1 for $75 used and could not turn it down.
Old Nov 11, 2009 | 03:55 PM
  #83
Zeitronix's Avatar
Used LC-1? Hope it works!
Old Nov 11, 2009 | 03:57 PM
  #84
EVO_MERLE's Avatar
works great i was there when we took it out of my friends car and then we put it in mine. Did not get it from the internet or Ebay. LOL
Old Nov 11, 2009 | 04:21 PM
  #85
Zeitronix's Avatar
The only way to do it.
Old Nov 11, 2009 | 05:56 PM
  #86
Chef-j's Avatar
Anyone have try haltech wideband on Evo? I tried this wideband on other vehicle, it works great.
http://www.injectedperformance.com/e....aspx?ID=10520
Old Nov 11, 2009 | 06:31 PM
  #87
geezevox's Avatar
Just ordered my Pro-sport Wideband. I'll post a review once its installed.
http://prosportgauges.com/wideband-a...ratio-kit.aspx
Anybody have any experience with this gauge??
I have the prosport wideband and I love it. It works great and the company is great about any problems (mine came with a small dent on the housing and they replaced it-no charge). Also, I compared the gauge readings to my tuner's dyno readings while my car was being tuned, and it was within a tenth at all times.
Old Nov 11, 2009 | 06:33 PM
  #88
EVO_MERLE's Avatar
Can u log with it?
Old Nov 11, 2009 | 06:42 PM
  #89
SyZyGy1394's Avatar
Originally Posted by stokEd
Skip the new *Analog* AEM UEGO (30-5130), it has no serial support and therefore cannot be used in Evoscan.
Can't wire it to the ecu and log from there?
Old Nov 11, 2009 | 06:43 PM
  #90
p8471's Avatar
zeitronix.
