Downshifting the X and going into Limp Mode
Old Aug 8, 2009 | 07:56 PM
Hrdcoreathlete's Avatar
As the title reads I was driving home tonight doing about 55 and got stuck behind someone driving real slow so I down shift and hit the gas to get around them and car went into limp mode...pulled over shut it off and turned it back on and went back to normal. CEL is still on but the car is runing fine so basically just wanted to know how many guys have had the same problem with their Evo X. My friend at work has an X and he has had his car go into limp mode about 4 times already so just wanna know if its a common accurance or not. If there is already a thread about this situation then if someone can point me in the direction of it I would be much appreciated.
Old Aug 8, 2009 | 08:32 PM
ice1874193's Avatar
stock or modded?
Old Aug 8, 2009 | 09:02 PM
EndlessRed's Avatar
pull the code first, then come back.
Old Aug 9, 2009 | 03:06 PM
stokEd's Avatar
I'm going to guess it's a p1235 from an overboost. Go to your local autoparts store and borrow their OBD scanner to pull the code. And the solution to yours and your friend's throwing codes is to have the cars properly tuned.
Old Aug 11, 2009 | 04:58 PM
bravo-x's Avatar
No... I've had mine for almost 6 months/5k miles. Have not put it into limp mode or thrown a CEL. I am running Cobb AP stg 1/93 map with HKS panel filter. No other mods.
Old Aug 11, 2009 | 05:12 PM
ilive2win's Avatar
that happend to me as well and found it it was a overboost problem and turned down the boost and hasnt happend since then
Old Aug 11, 2009 | 05:14 PM
i64X's Avatar
Full Perrin Stage III for me - I've never once had that happen. The only time I saw a CEL was when I blew a coupler off. I tracked my car pretty hard for a session a few weeks ago, no CELs then. Good times.
If you have a stock tune, get a Cobb and Stage I. If you have a custom tune, take it to someone who can tune better.
jman49127
Lancer Troubleshooting
Feb 17, 2017 07:22 AM
kraken2011
Jun 18, 2016 11:00 PM
wacboyjulian
Mar 5, 2014 10:08 PM
dsm
11
Feb 3, 2013 10:38 AM
05raslw
14
Oct 14, 2011 04:55 AM
