car tuned finally
Old Aug 10, 2009 | 01:54 PM
freshpl's Avatar
car tuned finally
mods:
AMS uicp and Short Ram Intake
I have been using 93 octane do I continue using that or can I use 91?
Boost at 24, pill removed
Old Aug 10, 2009 | 02:01 PM
Laz's Avatar
Laz
I have to ask: is it really worth switching to 91 if you're only saving like $1.20 a tank?
Great results
Old Aug 10, 2009 | 02:14 PM
freshpl's Avatar
Great results
cash is not the reason , i didn't know if they tune the car dependent on 91 or 93 first time i got a tune in my life so just wanted to be sure, ill stick with 93
Old Aug 10, 2009 | 02:39 PM
nj1266's Avatar
If the car was tuned on 93 octane, then use 93 octane.
I presume that you are using an Access Port and that is why the solenoid pill was removed?
There is no reason to remove the solenoid pill, btw. All it does is make the boost less stable and inconsistent. You can attain 24-26 psi and hold to 18-19 psi by redline with ALL the pills in place.
Old Aug 10, 2009 | 03:14 PM
freshpl's Avatar
don't have accessport ,I was told because of the large AMS intake I had a knock in order to prevent that had to raise the boost and take the pill out.
Old Aug 10, 2009 | 04:11 PM
Clipse3GT's Avatar
Where are you from if you went to BR for a tune?
Old Aug 10, 2009 | 05:15 PM
freshpl's Avatar
just north of ohio
Old Aug 10, 2009 | 07:15 PM
nj1266's Avatar
That does not make sense...So to cure the knock, the tuner removed the pill to add boost
Old Aug 11, 2009 | 05:28 AM
freshpl's Avatar
yea its odd but numbers are good now so everything's up to par i guess you could say
