Cams for the Xs
Old Aug 26, 2009 | 01:27 PM
miniend's Avatar
Cams for the Xs
anyone has ideas about good cams for the Xs
Which ones r good for everyday use and would still give good torque?
do I need to do the Valve Springs too ?
Old Aug 27, 2009 | 09:36 AM
ymr's Avatar
ymr
Check the Cosworth
Old Aug 27, 2009 | 09:41 AM
wilbdog's Avatar
I agree - Cosworth MX1s are where it's at.
Old Aug 27, 2009 | 10:49 AM
murlo26's Avatar
Cosworths are a nice upgrade.
They still keep torque thats for sure, I am making tons of low end torque.
You don't need springs with the cosworths if you keep the factory rev limit.
Old Aug 27, 2009 | 10:51 AM
LVSBB6's Avatar
There`s also JUN, Blitz and HKS.
Old Aug 27, 2009 | 11:30 AM
DG Motors's Avatar
If you are keeping the stock turbo on pump/meth, cosworth mx1's are a perfect solution. If you plan on running big boost with the stock turbo we have also had great results with the kelford stage 2 cams but you must upgrade the valvesprings!
Here are a few cars we have tuned with both:
Kelford:
https://www.evolutionm.net/forums/ev...ock-turbo.html
cosworth: https://www.evolutionm.net/forums/ev...-dg-tuned.html
Old Aug 27, 2009 | 11:48 AM
murlo26's Avatar
Kelford:
+1
I still think the cosworths aren't too much behind the kelford stg 2's. My cams are pretty lopey, but I know you guys know that, since you have put both in, and I could get mine to idle like stock but where is the fun in that, it still doesn't die on me And after seeing Buschurs gains with the DOM 2 40whp/40wtq I think until 35R land the cosworth and kelfords are pretty comparable. I would love to see some 35r's with kelford/cosworth comparisons, but I think we will have to wait for that one.
Old Aug 31, 2009 | 10:38 PM
miniend's Avatar
i want to get kelford stage 2... i want to get the boost high but i dont want to damage anything...
how high can i get the boost to if i use the car for dailydriving ... and what else should i change with the valvesprings to keep my motor safe... i am going to stay on 91 Octane though.
