need to nerf/valet mode my evo
Old Sep 27, 2009 | 09:59 AM
newcomer81's Avatar
Dropping my car off monday to get body work done (rear ended fri morning ) and i want to enable a valet style mode to add some piece of mind to the repair process. i have ecu flash and was going to load a stock base map and then drop the stationary rev limiter to 2k and the normal rev limiter to 4k. I was also thinking of zeroing out the waste gate duty cycles. anyone have any other suggestions? also which wgdc map do i need to zero out to lower boost?
thanks
Old Sep 27, 2009 | 05:38 PM
tephra's Avatar
zero out your Baseline Wastegate Duty maps (all 3)
Old Sep 27, 2009 | 06:06 PM
newcomer81's Avatar
thanks!
I just tested it and i got it up to 15 psi at 4k when it hit the rev limiter so i have a much better feeling now about handing the car to someone else. 2k stationary limiter makes me laugh
Old Sep 27, 2009 | 06:43 PM
HR2L's Avatar
Why would they even need to drive your vehicle (body work, not mechanical) more then 500ft at most to complete your issue. Log your miles with a picture that is time stamped or better yet im sure you will be having someone pick you up when you drop the car off for the work (have them confirm the odometer miles) Any unexplained miles, and it could be small claims court for that buisness.
Though your idea does offer the ultimate piece of mind...
Old Sep 27, 2009 | 06:52 PM
rogue's Avatar
or purposely put it in limp mode...
Old Sep 27, 2009 | 07:09 PM
newcomer81's Avatar
for the 5 minutes it took to do i think it was well worth it just for that reason
in case they do need to drive it up the road to a paint booth or somthing along that line i figure i'd at least make it drivable
Old Sep 27, 2009 | 07:11 PM
rogue's Avatar
Lol it will drive.. just very slow..
Old Sep 27, 2009 | 09:24 PM
delkat's Avatar
How would you purposely put it into limp mode?
Old Sep 27, 2009 | 09:37 PM
rogue's Avatar
Airflow check adjustment. Lower the boost cut threashold.
I'm nit saying to do it that way... It was another wat of thinking. Lol.
DormantBeast
13
Jul 9, 2017 07:38 AM
SW20Mike
Oct 20, 2013 10:29 AM
seeevo
Nov 9, 2009 01:17 PM
Bonestock!
Dec 12, 2006 01:55 PM
