Best Cold intake System for evo X
Old Oct 2, 2009 | 11:07 PM
BigT's Avatar
Originally Posted by Airportguy770
Noob question but do you need to get a tune after you put on an intake?
The evo X almost requires a tune after any modd. Once different load values are hit in the mivec/boost/timing/afr maps, everything is all out of wack.
Old Oct 2, 2009 | 11:08 PM
Airportguy770's Avatar
Damn, so every time you put a new part on, you have to go to a dyno for tuning?
Old Oct 2, 2009 | 11:12 PM
BigT's Avatar
You dont have to, but it would be smart. I'm sure you can get away with it, lots have. But the car will run so much better/safer with a tune. I did run my car with a testpipe/catback for a while and also with an UICP/intake. But, the Speed Circuit intake utilizes the stock housing like I stated before and the car ran nice. However, I never upped the boost until I tuned my ecu for it.
Old Oct 3, 2009 | 12:55 AM
blk-majik's Avatar
You'll 100% need a tune if you replace the MAF housing with an intake that modifies the size of the MAF housing. If it uses the stock housing or keeps the dimensions the same, there isn't as much of a need.
And good looks on the speed circuit one Didn't
Old Oct 3, 2009 | 07:13 PM
Jwilliams's Avatar
Best to do intake/exhaust mods first then get a tune that way you don't have to do it a bunch of times.
Old Oct 4, 2009 | 07:14 PM
stokEd's Avatar
Originally Posted by suprawillis
Bought the car with the injen kit already installed. It is a quality piece, but after doing a boost leak test, it was leaking air out of the MAF sensor. Not sure if there was supposed to be a gasket, but it was leaking pretty well. I put a thin coating of clear silicone and no more leaky.
Do you mean MAP sensor? No boost leaks pre-turbo.
Old Oct 4, 2009 | 07:26 PM
suprawillis's Avatar
I thought it was the MAF sensor. Anyhow yes it was leaking air through the flange. After I sealed it, I did another boost leak test, and I was hitting 25+ psi as opposed to hitting my max of 23. Not too much temperature variance in between tests.
Old Oct 5, 2009 | 07:38 AM
junetojudeto's Avatar
i think im definite. im probably leaning towards the ARC INDUCTION INTAKE BOX. i just need to see the specs on warrenty. if it dosnt void then ill just get it and install it asap
Old Oct 5, 2009 | 06:27 PM
Jwilliams's Avatar
Here's a review of my ETS Intake I just installed, overall very nice product, fitment was great and it really gives the car pick up.
Old Oct 5, 2009 | 09:00 PM
hey by any chance do you know if the ETS intake voids warrenty?
Old Oct 6, 2009 | 11:46 AM
Jwilliams's Avatar
As far as Mitsubishi is concerned ANY aftermarket parts will void a warranty. But unless the part itself is the cause of an issue they shouldn't give you any issues at the dealer. Unless the service manager is a huge tool that is.
Old Oct 7, 2009 | 09:56 PM
BoostinEv0's Avatar
is the ets maf intake considered a SHORT RAM Intake?
Old Oct 7, 2009 | 10:54 PM
1sicknickel's Avatar
I love my Short Ram AEM intake it has a good feel and sound once you tune the car. The best thing about the AEM is that its discreet and also carb legal if you are looking into those factors.
Old Oct 26, 2009 | 08:11 AM
well i ordered the ARC induction box it should be here within a few days i got it bought and installed for 400$
Old Oct 26, 2009 | 11:24 AM
rogue's Avatar
Originally Posted by BigT
www.speedcircuit.net
http://www.speedcircuit.net/product_...e65f0dc58a00a8
I have their cold air intake and it utilizes the stock MAS housing. I love it and my intake temps are always ambient if not just a tad hotter. My cruise LTFT is at 1.9 with the stock latency values.
I am using this CAI as well. Love it.
