Disabling the boost cut?
Old Oct 7, 2009 | 10:41 AM
seven_227's Avatar
Question Disabling the boost cut?
Any one knows how to disable the stock boost cut (Service required light) above 29 psi?
Car is tuned with EcuFlash.
Old Oct 7, 2009 | 02:17 PM
Hiboost's Avatar
You could disable it by setting the Boost Limits to 319% or changing the Boost Cut Delay Timer to 10,000 ms but you are better off raising the load % that it gets triggered at about 10-20% higher than the max you typically see at 29 psi. That way if you run 35 psi due to a WGA signal failing to open your Wastgate you'll hopefully save the engine.
Using EcuFlash you can edit the "Boost Limit" table to set the higher thresholds.
Old Oct 7, 2009 | 02:24 PM
seven_227's Avatar
Thanks! I'll give it a try.
I'm actually aiming for 29 psi, but sometimes between shifts boost slightly spikes over 29 psi, and that's when It hits boost cut.
dolphin888
Aug 29, 2013 07:52 PM
goofygrin
83
Aug 11, 2011 02:02 PM
eTiLiKo
25
Jul 1, 2011 09:41 AM
Rallyman
Oct 17, 2008 05:42 AM
StreetEvo
Feb 29, 2008 05:33 PM
