DW 1000cc's injector scaling needed
Old Nov 11, 2009 | 05:12 PM
criptballer's Avatar
Question DW 1000cc's injector scaling needed
i'm getting my DW 1000 on friday and switching over to e85 and i'm trying to find out if anyone has their latency maps they can post. Thanks guys
Old Nov 11, 2009 | 09:42 PM
delkat's Avatar
Scaling
Pump: 713
E85: 562
Latency
6.120
4.200
2.808
1.992
1.488
1.200
0.912
Old Nov 12, 2009 | 05:53 AM
Hiboost's Avatar
Are those first two latency numbers super important? I wasn't sure if those lower voltages had much of an impact or not or if it was mainly the 12 and 14.5 volt rows that had the most impact?
Old Nov 12, 2009 | 09:34 AM
delkat's Avatar
I'm not sure.
Old Nov 12, 2009 | 09:58 AM
goofygrin's Avatar
https://www.evolutionm.net/forums/ev...highlight=1000
search would have returned your answer for you (I searched for "1000" in this forum to find this post, it had almost the same title as yours).
Old Nov 12, 2009 | 02:45 PM
does anyone know why the scaling of e85 is lower than that of pump? i though the higher the number in scaling the more % of the injectors you use. right....? so if we need 30% e85 wouldn't that mean the scaling number would have to be higher that that of gasoline?
Old Nov 12, 2009 | 05:25 PM
GST Motorsports's Avatar
For scaling, smaller the number, more da' fuel.
For latency, higher the number, more da' fuel.
- Bryan
Old Jan 1, 2013 | 06:23 AM
Malaxa's Avatar
DW 1000 injectors gave you satisfaction?
You could set them perfectly that AFR to be perfect?
Do not you want to share your experience?
foxbat
Apr 21, 2017 12:50 PM
kcn0
Oct 6, 2015 09:32 AM
JonGonzo
Jun 14, 2013 03:50 AM
Ludo
Jan 21, 2013 12:52 PM
twinturbogreg
Aug 30, 2011 07:24 AM
