Stopping the fuel trims affecting WOT fueling
Old Dec 7, 2009 | 04:47 AM
  #106
tephra's Avatar
The table was actually stolen from someone in CT9A land - I forget who
But yes I thought about running 3 legitimate LTFT's, but really without exhaustive testing it's hard to know exactly how to set it all up.
I found that the mid trim varied so much that the stock setup really wasn't ideal. So "disabling" it seemed like the best option. So far my WOT AFR's have been much more predictable.
I settled on 343/350, since this is about 140-160 load (at 2500rpm) .
Same 1byte MAFHz setup on the X btw...
Old Dec 7, 2009 | 12:49 PM
  #107
mrfred's Avatar
Have you found the fuel trim calc subroutine for the Evo 10? The subroutine for CT9A is much simpler than I thought it would be. Looks like the LTFT mid and high are calculated in exactly the same manner.
Old Dec 7, 2009 | 07:38 PM
  #108
nj1266's Avatar
Originally Posted by GST Motorsports
Ok did this on a GSR today. It didn't zero out the LT trims, however I did notice that the LTFT had no effect on Open Loop fueling anymore.
Awesome.
I guess the LTFT in evoscan is different than the addresses you are logging Tephra?
Thanks again for finding this.
- Bryan
From a tuning aspect would the LTFT change trigger a CEL (system too lean) if the trims go too far positive (+12.5%) even if you disable their effect on AFR at WOT?
If the trims no longer impact AFR at WOT, is there a way to disable the CEL coming on as a result of the LTFT going max positive because of the use of intakes?
Old Dec 8, 2009 | 09:58 AM
  #109
Appauldd's Avatar
These crossover LTFT points were discovered in part by my constant begging for adjustment of the Hz values for running aftermarket intake pipes that affect idle Hz values. By increasing the value you can get LTFT low to adjust quite easily for any intake. Simply log your idle Hz and increase the low values to make sure that you are ideling under them.
I love that you discovered more of a use for them. I always wondered why the high was never called. Now I know.
Thanks again Tephra....you are the EVO GOD ! !
Old Dec 8, 2009 | 10:30 PM
  #110
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
It is the same code compiled for different processor.
Old Dec 10, 2009 | 12:51 PM
  #111
shadow1's Avatar
Originally Posted by tephra
You should be able to see the trim being used by logging MUT50 - same formula as the other trims...
You can log MAFHz with MUT1A (x*6.25) and then you should be able to see when the STFT drops to 0% (closed loop)
This is a related side issue. The published formula for fuel trims for Evoscan and Misulogger is (x*.1961)-25. However, isn't the exact formula [25(x-128)]/128 which calculates to (x*.1953)-25. Which one is correct?
Old Dec 10, 2009 | 01:21 PM
  #112
Clipse3GT's Avatar
I use this formila, works fine.
Old Dec 10, 2009 | 03:50 PM
  #113
tephra's Avatar
I use x * 0.1953125 - 25 - which is basically your formula.
In truth it doesn't really matter either way. I prefer mine/yours since it results in 0% and not 0.1008 or whatever
Old Dec 11, 2009 | 04:09 AM
  #114
bluexgyr's Avatar
log MUT50 guys... that is the copy of the current LTFT in affect...
bryan - can you send me the ROM in question? I'll double check it
Could you please confirm MUT50 for 53040010 or the address for the MUT table
Old Dec 11, 2009 | 02:33 PM
  #115
bluexgyr's Avatar
Think i found mut table 3e3b8
Old Dec 11, 2009 | 03:11 PM
  #116
tephra's Avatar
yep thats right...
Old Dec 16, 2009 | 04:30 AM
  #117
boostin20's Avatar
sub'd
Old Jan 1, 2010 | 10:35 PM
  #118
nj1266's Avatar
Does this work on the 2010 USDM Evo X? I added the code to the 2010 rom xml file and got the same table/values for the 2008 USDM Evo X. Does that mean that it should work?
TIA
Old Jan 2, 2010 | 07:05 AM
  #119
Appauldd's Avatar
This tweek is great.....we can leave Lean Spool enabled and now do WOT pulls that are consistant from pull to pull.
Old Jan 26, 2010 | 04:38 AM
  #120
YaroRS's Avatar
doesn anyone know location of mut table for 5304007 ? Need it for logging mut50 adress .
